Results 1 to 6 of 6
Thread: newbie asking questions about hand pump
    DIY Member rbig's Avatar
    Jan 2008
    Florida
    Default newbie asking questions about hand pump
    I have a sprinkler 2hp pump sitting on the ground, on concrete blocks. It looks like it goes into a 2" line, straight down. There is a check valve at ground level.
    I would like to have a hand pump, in case power fails. One similar to those sold by HarborFreight. Our well is probably 20' deep.
    Can I cut into this and rig the hand pump?
    Some things I've read say I should run a 1 1/4" line down from the hand pump with a foot valve on the bottom. If this is the case, I'd say I can't use the 2" pipe coming up--------or-------can I use it with adapter fittings?
    Is there a way I can use both my sprinkler pump and a hand pump?
    Moderator valveman's Avatar
    Mar 2006
    You can use 1 1/4" if the OD of the couplings has been turned down. But you can't have both in the same 2" well. Probably be easier to drive another point well just for the hand pump.
    DIY Junior Member Wallysurfr's Avatar
    Apr 2013
    Wall, NJ
    I thought about trying that but I have 1.25" coming out of the well. I was going to have a T instead of the elbow heading to the pump then off the top of the T a nipple and the hand pump. Is that not possible?
    Would the hand pump add to my air leak? Can air get past the leathers? Could you put a valve in between the T and the hand pump to turn it on and off?
    I also had 17 connections and an air leak so my first order of business is getting the well to work properly. Might be driving another point! UGHHH!
    Mar 2006
    Have you checked out hand pumps? They should have a pump barrel at the bottom and a shaft going from the barrell to the handle. I don't think you will get the barrell to fit down the 1 1/4" pipe. And even if you can, the packing seal around the shaft under the handle will let air suck in when using the jet pump.
    Apr 2013
    Wall, NJ
    oh ok I guess my newbieness is showing. I have a pitcher pump that I wanted to do this with. I guess that's different than a hand pump?
    Mar 2006
    Pitcher pumps, hand pumps, same thing. They have a shaft that goes down to a pump barrell. The pump barrell probably won't fit down the 1 1/4" pipe, and if it did you can't keep air from sucking in around the hand pump shaft seal when using the jet pump.
  1. Hand Driven Well Newbie
    By stevenb in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-05-2008, 04:05 AM
  2. Newbie questions
    By billybarty in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-05-2008, 09:33 AM
  3. newbie w/ ejector pump questions
    By BOTTLEDZ28 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-01-2007, 05:11 AM
  4. Newbie Well Questions
    By sjwass in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-16-2007, 02:21 PM
  5. Newbie Gas Questions
    By stevep in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-25-2006, 12:32 PM
