Results 1 to 10 of 10
Thread: I destroyed my closet flange
    DIY Junior Member ericp's Avatar
    Dec 2012
    Arizona
    Default I destroyed my closet flange
    The metal ring on my closet flange was rusted away. I cut off the top of the flange with a dremel, which left about 2 inches remaining around the outside of the waste pipe. When I couldn't get the rest of the ABS off of the pipe, I Googled and learned about solvent welding.
    I have no idea how to fix this and would greatly value your suggestions. The waste pipe is 3 inch ABS. I bought a 3 inch inside fit ABS flange. But, I've read that this size flange is to be avoided. It has a plastic ring, also best to avoid.
    Any ideas would be gratefully received.
Size:  34.3 KBName:  008.jpg
Size:  70.7 KBName:  010.jpg
Size:  70.1 KBName:  014.jpg
Size:  63.7 KBName:  015.jpg
    Too bad you cut off all that...they make repair rings that you could have used and not be in this situation. One type is hinged and would have fit in the notch the old one fit into, others are just a ring that can be bolted down to hold the flange bolts. How much height of straight pipe have you got to work with? If it's enough, you can pick up an inside pipe cutter (essentially a small circular saw on a shaft) to cut off enough, then glue on a coupling, a short piece of pipe, and a new flange. You could try to cut vertical notches in the flange, then trying to peel it off. If the joint is well done, it will damage the vertical piece of pipe, but maybe not enough to prevent a decent seal. If you have access or can gain it from underneath, you could maybe cut out more if required.
    Yakima WA
    This may be beyond your ability to repair. You will certainly be time and probably money ahead if you call a plumber to install a new flange properly. Sometimes the best advice a DIY can get is to know when it's time to call for help.
    Jun 2009
    Canada
    Access from below the concrete slab Jim?
    If you cannot find a plumber with some very specific tools you're going to be renting a jack hammer and taking up that floor.
    Dec 2012
    Arizona
    There is about 3.5 inches of straight pipe. Then, it starts curving towards the wall. But, about 1-1.5 inches of the straight pipe appears to be inside of an elbow fitting. There is 2 inches of flange remaining. So, if I cut off the straight pipe just below the flange, then I'll be right at the top of the elbow fitting.
    Retired Machine Repairman wptski's Avatar
    Oct 2012
    Warren, MI
    Quote Originally Posted by ericp View Post
    That would leave you with a portion of the straight piece inside the elbow, correct? You'd have to remove that to replace the straight piece. I've seen cutters powered by a hand drill to remove that but that was on much smaller PVC pipe.
    Bill
    Just a DIY'r
    Jan 2008
    It would cost you almost nothing to try the inside fitting flange and see if you have problems flushing over the next couple of weeks. If you are not happy with results, you cut the slab so that the closet bend and flange can be replaced properly.
    Can't tell if it is thinset around there from the tile, or concrete. There may or may not be enough room for a coupling if you cut it off inside. If you can get the flange out of there, you can use something like a RamBit to bore out the socket of the fitting below so you can glue a new one in. The cost of the tools may make it expedient to call a plumber, although the pieces aren't all that expensive. Depends on exactly what you have and where it is. Plus, would you ever use the tool(s) again? IF so, then the cost per use goes down, maybe way down.
    Dec 2012
    Arizona
    Thanks for all of your responses. The RamBit idea sounds like a good solution. I'll let you know if the plumber goes that route. Considering how slow I work plus the cost of fixing my mistakes, it's probably more cost effective to call a professional. Thanks again.
    Oct 2012
    Warren, MI
    Ah! That's what you call that tool.
    Bill
    Just a DIY'r
  1. Street 45/45 closet flange vs. spigot closet bend
    By Noth Jersey in forum Toilet Forum discussions
    Last Post: 12-03-2012, 09:27 PM
  2. closet flange to closet elbow distance
    By Pabs in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-13-2009, 07:12 AM
  3. Destroyed Inside Flange Woes
    By obsidian97 in forum Toilet Forum discussions
    Last Post: 09-28-2008, 04:46 AM
  4. Questions about closet bends/closet flange.
    By ricky01 in forum Toilet Forum discussions
    Last Post: 08-27-2008, 02:13 PM
  5. How I destroyed my lawn (Sprinkler Troubleshooting)
    By craniac in forum Irrigation / Sprinkler Forum
    Last Post: 06-25-2008, 09:37 AM
