Results 1 to 2 of 2
Thread: Moen 1200b cartridge stiff
    DIY Junior Member cpowers's Avatar
    Aug 2012
    indiana
    Default Moen 1200b cartridge stiff
    Had a Moen solara faucet for several years, i have replaced the cartidge before and it was a plastic one 1225 i believe. After about 3 or 4 years it started leaking so i called moen and they sent me a 1200b. all seem to install fine, but things are not like before.
    The handle is very tight on the cold side, does not move nearly as smooth over all, and seems to bind at the extremes. Also it seems to have somewhat less flow.
    Is this nature of the beast, do i just need to get a 1225?
    Would disassembly and silicone grease solve anything?
    also the small spring washer has broken twice, what am i doing wrong with that? Thanks!
    Chris
    http://www.moen.com/shared/docs/expl...ews/7570pt.pdf
    I prefer the 1225 for smoothness.
    The brass tends to last longer, but may be stiffer. It's okay to pull it apart and lube them. Plumbers do that all the time.
  1. Stuck Moen Cartridge
    By sabell in forum Plumbing Forum Discussion & Blog
    Last Post: 05-20-2013, 09:54 AM
  2. new moen cartridge won't go in
    By skylyn in forum Shower & bathtub Forum & Blog
    Last Post: 03-15-2011, 11:40 AM
  3. Moen cartridge stuck
    By scorpsista in forum Shower & bathtub Forum & Blog
    Last Post: 05-09-2009, 03:31 PM
  4. Moen cartridge install
    By Roadie in forum Plumbing Forum Discussion & Blog
    Last Post: 12-08-2008, 12:14 PM
  5. New Moen Cartridge - Very Little hotwater
    By Redman67 in forum Shower & bathtub Forum & Blog
    Last Post: 11-29-2006, 03:50 AM
