Results 1 to 3 of 3
Thread: Air gap faucet install
    DIY Junior Member Scott Kayser's Avatar
    Oct 2013
    Virginia
    Default Air gap faucet install
    I recently purchased a reverse osmosis filter system which has an air gap faucet. The existing hole in our quartz countertop is 1.5". The faucet requires a hole up to 1.25". The base of the faucet does not cover the hole in the quartz. Where would I find some type of escutcheon that i can mount this faucet on to reduce the size of the hole? Is there something else I can do to make this work?
    DIY Senior Member Reach4's Avatar
    Sep 2013
    Cheap way: get a hole plug with the finish you want. Drill or punch a hole in it. Does the faucet really need a 1-1/4 inch diameter hole? I would have thought a smaller hole would work.
    You could look around the sink drain fittings. Maybe you could find a slip joint nut that would be used.
    Fancier way: buy a new RO socket that is made for 1-1/2 inch hole. Some are not so expensive. Some have built-in TDS sensors.
    Oct 2013
    Virginia
    Thanks. The hole can be as small as 1". I was trying to do this on the cheap, but a new faucet may be the best answer. I think I'll try the hole plug first.
  1. Blanco faucet install
    By big2bird in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-14-2012, 06:31 AM
  2. Touchless faucet install
    By bpetey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-29-2010, 06:13 PM
  3. Roman Tub Faucet Install
    By countryhouse in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-26-2009, 05:45 AM
  4. Jacuzzi Tub faucet install
    Last Post: 04-16-2009, 11:09 AM
  5. Basic faucet install
    By lotsoleaks in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-27-2007, 07:37 PM
