Results 1 to 6 of 6
Thread: Help with Identifying Tub Faucet Brand/Model
    DIY Junior Member Lisa Jones's Avatar
    Dec 2012
    Ontario
    Default Help with Identifying Tub Faucet Brand/Model
    Our tub handle broke off last week, and since then, we have been on a bit of a quest to identify the make and model of it to get a replacement handle.
    Pics included... the most unique identifying feature, in my opinion, is the "Hot" and "Cold" words written in cursive writing.
    Any help identifying this would be great! And if that's not possible, what are my easiest options to fix this problem?
    THANKS!
    The picture of the plate is confusing, I would assume your picture of the plate is sideways, unless they installed the faucet on its side, but the screws are oriented for a proper installation. It would be better if we could see what is under the plate, since that is a better indicator of the manufacturer than the handle or plate. Delta is one company that uses a "D" shaped stem, BUT, if your bottom picture is correct, it appears that the set screw does NOT contact the flat spot on the stem, although the appearance could be wrong due to some distortion in the picture.
    Dec 2012
    Ontario
    Thanks for your reply. I think I managed to identify the brand by finally finding a brand name on the sink faucet. The two look very similar so I assume there is a great chance that they are the same brand. Well, that brand is Foremost, who no longer make many faucets at all and who tell me they don't have any faucet parts anymore. REALLY wish the previous owners had used one of the more reputable brands.
    What are my options now? Will the Universal kits that Pfister sells do the trick? I have very little knowledge of all this and I would love to keep this a very simple DIY job if possible. Very simple!
    Plumber jimbo's Avatar
    NO on any interchangeable parts.
    Foremost is a Canadian (chinese) company, into toilets and other fixtures. They make the HD Glacier Bay toilets. Don't know if it is the same company as your faucet.
    If you remove the pie pan, and take a picture of the faucet body, that would be a big help.
    Dec 2012
    Ontario
    Here is a pic without the pie pan part.
  1. Help identifying type of stem/ which brand of shower faucet to get.
    By Marksluce in forum Shower & bathtub Forum & Blog
    Last Post: 06-30-2012, 01:53 PM
  2. Indentifying faucet brand / model
    By drewster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-12-2011, 06:49 AM
  3. Need help identifying the brand and model number of valve
    By ronnieray in forum Irrigation / Sprinkler Forum
    Last Post: 07-04-2010, 05:55 PM
  4. Can you tell me the brand and model of this faucet?
    By dwclapp in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-12-2010, 07:16 AM
  5. Please help in identifying the faucet manufacturer/model
    By kenga_can in forum Shower & bathtub Forum & Blog
    Last Post: 02-16-2009, 06:46 AM
