Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Bought home, need help with water softener
  1. #16
    Nov 2005
    Central Florida
    I guessed that, but appreciate the confirmation.
  2. #17
    Dec 2009
    Alaska
    Quote Originally Posted by Mikey View Post
    I've had no problems with mine for 12 years. It's a manually-controlled valve; can it be upgraded to the metered version? Is it worth it at this point in its life, or would I be better off replacing it?
    A meter timer assembly, meter assembly with the right angle and the cable......... no need for the full power head.
  3. #18
    And with only two 'mature' people in the house that probably have consistent daily water use patterns, your day timer if programmed for good salt efficiency will do the same job a metered unit would except for times of seriously increased water volume use that would use up all of the 24hr reserve.
  1. Replies: 2
    Last Post: 07-10-2012, 04:19 AM
  2. Softener system for new home - ATTN GARY
    By riverside67 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-24-2010, 09:57 AM
  3. Best Home Water Softener System & PEX or CPVC?
    By inforapeek in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-30-2009, 06:28 AM
  4. Best Home Water Softener System & PEX or CPVC?
    By inforapeek in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  5. New Home Plumbing/Water Softener
    By Dbrule013 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-09-2008, 06:09 PM
