Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
Thread: weird wiring and wierd voltages on 3 dual switches...
  1. #31
    DIY Junior Member meweber1000's Avatar
    Dec 2012
    Dallas
    IF they are adjacent, the #8 and #10 should be on different legs which would create a 240v circuit and blow one or the other, and possibly the main breaker, if they were connected together. The same with #12 and #14. This is a valid assumption since your pool pump is 240v and it uses adjacent breakers. Something is erroneous in your diagnosis. You could safely connect #8 and #12. And #10 and #14.
    Thank you hj. I embarassingly have typos in my very pretty diagram. It's actually 8 and 12 connected and 10 and 14 connected. Do you have any ideas on an application that might have required this? Security systems or cameras perhaps? I would just really like to know why they did this before I bring an electrician out here to make it safe.
  2. #32
    Dec 2012
    Dallas
    I see a safety issue as you have it: the load on ONE switch could short, drawing well in excess of 20 amps and the NEITHER breaker might trip until he total current thru the switch and load wiring neared 40 amps
    Jimbo, thanks. That was my first thought when I saw this. I'm going to get it cleaned up by an electrician, but I'm going to do some crawling around in very tight spaces first to try to find why the heck they did this in the first place.
  3. #33
    Dec 2012
    Dallas
    Quote Originally Posted by ActionDave View Post
    meweber1000, from the photo you posted I can tell you that the switches can feed two different loads from two different breakers.
    I can't tell if they are wired properly.
    I can tell you that a device like the switch you have, when fed from two different breakers should be on a breakers that have a common trip.
    The panel you have is obsolete and has a bad reputation. If you do a web search on FPE panels you will find no shortage of negative comments.
    Thanks. We are aware of this. We probably should have bulldozed the house...it has a zillion things out of code.
  4. #34
    Jun 2007
    North Carolina
    Quote Originally Posted by meweber1000 View Post
    Save yourself some time and trouble because that question is simple to answer. They had no idea what they were doing. The sad part about this thread is that when someone else comes along that don’t know what is going on does not help matters one bit.
    The safe solution is very simple and that is to call someone with a lot of experience to investigate what is going on.
  1. Wiring light switches.
    By piperca in forum Electrical Forum discussion & Blog
    Last Post: 09-09-2009, 05:47 AM
  2. wiring two switches for a gas fireplace
    By docpops in forum Electrical Forum discussion & Blog
    Last Post: 12-11-2008, 12:48 PM
  3. Wierd shower drain set up
    By Mark JW in forum Shower & bathtub Forum & Blog
    Last Post: 10-29-2007, 06:36 PM
  4. Weird Switch wiring
    By ms21117 in forum Electrical Forum discussion & Blog
    Last Post: 08-14-2007, 09:40 AM
  5. wierd hot water situation
    By John in T.O. in forum Plumbing Forum Discussion & Blog
    Last Post: 04-25-2005, 04:52 PM
