Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Damaged Toilet Drain Pipe
  1. #16
    Jan 2008
    Copper will have a smaller o.d. than c.i. or PVC. I would seek out the right coupler.
  2. #17
    It's not the copper end that is in question. It is the CI end. CI O.D. for 3" pipe size is 3.8 inches or larger depending on class. PVC O.D. is 3.5" This suggest that the coupling would be a bit large for the PVC but it was tight. I had a hard time getting it on.
    Louis
  3. #18
    Jan 2008
    It should fit snugly. If it is sloppy loose, that would be a problem.
  4. #19
    It is snug.
  1. Toilet drain pipe issue
    By Fantom in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-21-2012, 06:10 PM
  2. Driven pipe damaged?
    By rbhb2 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-25-2010, 10:53 AM
  3. Sleeving of damaged cast iron pipe in slab
    By ID4563 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-26-2009, 02:45 PM
  4. toilet drain pipe size
    By rdboi in forum Toilet Forum discussions
    Last Post: 05-19-2005, 09:33 AM
  5. Toilet Drain PVC Pipe Size
    By Oscar15 in forum Toilet Forum discussions
    Last Post: 01-24-2005, 06:46 PM
