Results 1 to 10 of 10
Thread: What type of sealing compound to use for this situation
Hybrid View
    DIY Member Kimster's Avatar
    Jul 2010
    Manitoba
    Default What type of sealing compound to use for this situation
    Hi all! Still working on the bathroom reno. I have copper stub-outs with sweat-on brass 1/2 in female threaded adapters at the end. I have stainless steel 1/2 in male threaded external shower valve adapters (Grohe) that need to get screwed into the brass. Any special kind of pipe dope I should be using for this situation - stainless to brass? The threaded portion of these adapters will eventually be covered by tile. If you need pictures, I will get some for you.
    You do not need anything special to seal that connection - tape and/or pipe dope will work.
    Jul 2010
    Manitoba
    Thanks, jadnashua! I thought I read somewhere that when you're dealing with stainless on another metal, that the pipe dope had to be anti-galling. Maybe this is true of all pipe-dope? Any brand you particularly like? All the stuff in the box stores here is Oatey, but I can go to the plumbing supply for other stuff if there's better out there.
    Stainless on stainless can cause problems...wouldn't expect you'd have problems with this...plus, it's not like you will be installing and removing it regularly!
    Jul 2010
    Manitoba
    Gotcha! Thank you!
    If this is for a surface "shower wall". are you sure they are not chrome plated brass?
  1. What is the difference between type L and type M copper pipe
    By Dom Z in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-09-2009, 09:39 AM
  2. Removing Compound
    By shluffer in forum Remodel Forum & Blog
    Last Post: 05-21-2008, 05:31 AM
  3. Self Leveling Compound
    By ttw4454 in forum Remodel Forum & Blog
    Last Post: 01-20-2008, 02:33 PM
  4. Type M vs.Type L copper for repipe
    By Santa Cruz Remodel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-17-2006, 07:08 PM
  5. Buy a compound miter saw or keep the one I have?
    By smhowell in forum Remodel Forum & Blog
    Last Post: 05-22-2005, 05:39 PM
