You will want to get a tank big enough that your pump will run at least a minute during cycles OR go with the small "pside-kick" that gives you constant pressure and keeps your pump from cycling on/off making it last longer.
Someone with more knowledge than me will be along and can explain all that better--but I do know with just a pump and tank the bigger the tank the better as far as making the pump last longer,plus dont get a cheap tank. I have Well-X-Trol tanks myself and havent had any problems with them.
