Page 6 of 6 FirstFirst 123456
Results 76 to 78 of 78
Thread: Curbless Shower
  1. #76
    DIY Member Freddie's Avatar
    Dec 2012
    Ottawa
    John,
    Seems like all the drains have some type of drawback or negative comments from people online.
    Proline - floor cutting and potential to weaken floor / deflection problems may occur
    Kerdi - many are not so sure of the foam pad that they use, 1" high
    ACO - some have said that it has little flow in the channel an can begin to stink,some don't like the flange version.
    Noble - internal of drain has too many nooks and crannies that can catch lots of junk and not all that easy to remove drain lid, Also is 1.5" high.
    So I think you have to just find one that works for you and then try to work around this deficiences. Don't you think?
  2. #77
    Jul 2009
    North Vancouver, BC
    post(s) deleted by John Whipple
  3. #78
    Dec 2012
    Ottawa
    Ok, so sounds like cleaning is not a problem really with any of them and they all need it. I will think about adding a nice trim on the tile at entrance to drain to protect grout below tile; at least the exposed grout will then be at the surface between the tile and the trim.
    Care to share your recommendations / suggestions for floor strengthening with the Proline drain?
  1. curbless shower
    By tucker2 in forum Shower & bathtub Forum & Blog
    Last Post: 02-10-2014, 02:04 AM
  2. ADA Curbless Showers in a Residence
    By PA Tile Guy in forum UPC Plumbing Code Questions
    Last Post: 07-18-2011, 05:01 PM
  3. Building 2 curbless doorless showers, need advice
    By crayola32 in forum Shower & bathtub Forum & Blog
    Last Post: 06-26-2011, 06:26 PM
  4. bath remodel curbless shower layout
    By grymes56 in forum Shower & bathtub Forum & Blog
    Last Post: 02-08-2010, 07:14 AM
