Results 1 to 10 of 10
Thread: Outlet inside peninsula cabinet
    DIY Member JMingrone's Avatar
    Aug 2006
    Default Outlet inside peninsula cabinet
    I'd like to put a utility outlet on the end of a peninsula. The cabinet is a slide out trash container and there's enough clearance inside for a shallow outlet box, so no problem there. What i'm not sure is how you run the cable to the box. Plain old Romex? Wire mold? Other? The feed comes up through the floor from the basement.
    Thanks,
    Jay
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    Plain old romex if nothing is going to beat it up when the trash container is used. The feed is supposed to come off of the GFCI protected kitchen counter top circuit.
    Aug 2006
    Thanks Dave. And for the reminder about the GFI.
    quote; The feed is supposed to come off of the GFCI protected kitchen counter top circuit
    And why can't it have its own feed and GFCI receptacle?
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    It can. But it will not fit in a shallow box.
    Sep 2012
    Anaheim, Ca.
    Quote Originally Posted by JMingrone View Post
    Thanks,
    Jay
    I would use M/C 90 to feed this, and find a way to get a deeper box in there. Perhaps a 52OW, and have it stick inside the cabinet. We do that for school labs all the time.
    You can always use a GFCI breaker rather than trying to use a GFCI recepticle if depth is an issue. It's just that resetting it may be more of an annoyance but the thing should not trip it, and if it's dedicated, it normally won't be an issue.
    Aug 2006
    Well, after all the careful planning, I feel really foolish about not having run a branch off either of my 2 GFI countertop circuits, which would have been simple before the walls were up!
    Jim- good idea about a GFI BREAKER as a work-around.
    Jay
    Feb 2009
    Colorado
    You can do that too.
    quote; Jim- good idea about a GFI BREAKER as a work-around.
    I assume your circuit breaker panel is in the basement. Here it would be outdoors, and would not be "fun" to have to go outside to reset it, especially if it was raining like it was last evening.
  1. Replies: 9
    Last Post: 12-11-2012, 12:01 PM
  2. Kitchen peninsula venting
    By bsperr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-26-2010, 05:48 AM
  3. Gas Pipe Inside Cabinet
    By ttbean2 in forum Remodel Forum & Blog
    Last Post: 10-04-2008, 07:51 AM
  4. Replies: 9
    Last Post: 07-18-2008, 07:16 PM
  5. kitchen peninsula outlet
    By geandham in forum Electrical Forum discussion & Blog
    Last Post: 06-25-2008, 04:45 AM
