Results 1 to 8 of 8
Thread: Airline for checking water level?
    DIY Junior Member DeepWell's Avatar
    Dec 2012
    New Mexico USA
    Default Airline for checking water level?
    I was told I should install an airline in my well to make checking water levels easy.
    I agree, this would be very handy, especially since we seem to get further and further in a drought with no relief in sight.
    Is there a special tubing I should use? I don't want this to start cracking/deteriorating down hole.
    DW
    DIY Member tvl's Avatar
    Jul 2006
    South Carolina
    Hi DW!
    Refer to this thread for additional information: http://www.terrylove.com/forums/show...ure&highlight=
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    How about buying a Well Sounder? I have one and it works great. I don't have to worry about contamination issues and there is no installation procedure. I think it was $1000.00 and I bet you couldn't put an airline in your well for that price.
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    Actually craig the airline is just a piece of poly-tubing taped to the side of the drop-pipe. You apply pressure to it and see what it holds to determine the water level. Probably about $20 for the avg. person.
    Apr 2012
    ct
    I'm familiar with how they work, but I think in a previous post he stated that the well was 800+ feet deep
    Dec 2012
    New Mexico USA
    I actually made my own sounder that I used before, but the air line will be better for keeping contaminates out.
    The air line was $90 with my company discount (from Granger) and it's 150psi USA tubing.
    I still need to get a few of the miscellaneous pieces to make it work, compression fitting, Tee, Schrader valve & gauge. Shouldn't be much $ with the gauge being the most expensive (of the remaining items).
    Apr 2012
    ct
    My mistake, I misunderstood that you wanted to put an airline in when the pump was out of the well
    Moderator valveman's Avatar
    Mar 2006
    800’ of ¼” poly is not very expensive. The problem with an airline for water level detection on a deep well is the amount of air pressure available. A 100 PSI compressor will only show 231’ of water standing above the pump. I use to test a lot of 1200’ to 1600’ wells using a ¼” rubber hose. We had to use a tank of Nitrogen with a regulator to get enough pressure to go that deep.
    An airline will show the water level dropping, but you have to air it back up to show an increase in water level. An airline is the only way I know to detect a true pumping level. The airline will not pick up water falling from perforations that are high up in the casing, as many sounders and electric current detectors will.
  1. Checking E-Mail Without Opening it.
    By DonL in forum Computers and Stuff
    Last Post: 05-16-2011, 05:15 PM
  2. Toilet Bowl Water Level Alternates Level and Flush
    By leichte in forum Toilet Forum discussions
    Last Post: 09-06-2010, 10:21 AM
  3. Newbie from Chicago checking in
    By 87vertgt in forum Plumbing Forum Discussion & Blog
    Last Post: 09-17-2009, 04:22 PM
  4. Checking Water Level - Sandpoint
    By mistermango in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-18-2009, 09:35 AM
  5. Checking Electric Water Heater Parts
    By white tiger in forum Plumbing Forum Discussion & Blog
    Last Post: 12-26-2006, 08:17 AM
