Results 1 to 6 of 6
Thread: Blue water pipe?
    DIY Member rayh78's Avatar
    Sep 2008
    Virginia
    Default Blue water pipe?
    1950 built house.
    At sometime sewer and water line replaced both in same trench.
    Sewer is ABS.
    Water line is some type of blue poloy pipe. Was is it?
    A light color blue and not like the old blue/grey quest pipe.
    Was connect with a barb fitting and hose clamp just like I have seen with the black poloy pipe used for main water lines.
    Looks and feels like the black poloy pipe but a blue color.
    thanks
    DIY Member boardable's Avatar
    Sep 2012
    San Jose, Ca
    This is most likely PEX. Look it up. A very neat set up. I prefer copper but most likely the previous owner had a re pipe done in PEX for cost.
    PEX would NOT normally be connected with a barb fitting and hose clamp. ANd unless it was done after the "PB era" PEX was not even being used.
    Sep 2008
    Virginia
    Quote Originally Posted by boardable View Post
    Pretty sure it is not Pex. I used a lot of that. And the blue is a lighter color from the blue pex I have seen.
    All I know for sure is that it was installed before 1999.
    Looks, cuts and feels just like the black poloy pipe I have used as water main lines to meter. Just never heard of it coming in a light blue color.
    I just finished splicing into it as I needed to extend it under the house. Used the same barb union as the black well pipe.
    Was galvinized from 3 ft out from foundation running thru crawl space to main shut off.
    DIY Junior Member kookla50's Avatar
    Oct 2013
    Arizona
    Could youplease look at my post from yesterday and tell me if this is the same pipe you were talking about. Blue outside black inside. Thanks
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    There are a few guys up here that use a light blue poly type pipe for the lines from the well to the house, it connects just like black poly with an insert fitting and double clamps. I think it is rated for 200 psi.
  1. blue grey water coming from tub
    By coopdedoo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-06-2011, 01:40 PM
  2. Help identify this blue pipe?
    By thebordella in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-06-2010, 03:40 AM
  3. Blue stain in tub. Not acid water. Electrolysis?
    By boerdoc in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-03-2009, 11:33 PM
  4. Blue/Green oxide on pipe feeding HVAC unit
    By AJTSheppard in forum HVAC Heating & Cooling
    Last Post: 10-22-2008, 06:31 PM
  5. Mysterious Blue Water
    By agtess in forum Toilet Forum discussions
    Last Post: 09-26-2005, 10:57 AM
