Results 1 to 2 of 2
Thread: Bradford white water heater leaking from top
Threaded View
    Question Bradford white water heater leaking from top
    Our Bradford water heater started leaking from the top this evening. We actually discovered the problem as it was leaking from the fire detector in our son's room (water heater are in the attic). We turned he water off which stopped the leak. Testing to figure out what was happening, we turned the water back on to discover only 1 tank is leaking so we can still use water on 1/2 of the house. UPDATE: We tested turning water back on only to find that the water heater is leaking from the bottom? HELP!!
    What could the water heater problem be? Tanks were installed in 2004.
    Thanks for the help!
  1. Bradford White water heater leaking after 3 months?
    By SocialDx in forum Water Heater Forum, Tanks
    Last Post: 09-29-2011, 08:08 AM
  2. Old Bradford White Water Heater leaking... Replacement options?
    By David Jones in forum Water Heater Forum, Tanks
    Last Post: 08-28-2011, 12:39 PM
  3. Is new Bradford White water heater too old?
    By VtaLady in forum Water Heater Forum, Tanks
    Last Post: 07-08-2011, 07:19 PM
  4. Leaking Bradford White Gas Hot Water Heater
    By Mark in Virginia in forum Water Heater Forum, Tanks
    Last Post: 03-29-2011, 07:58 AM
  5. Bradford White Water Heater ???
    By Master Brian in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-05-2009, 02:26 PM
