Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Newbie seeks advice on simple-looking leak
    Default Newbie seeks advice on simple-looking leak
    Found a leak under my bathroom sink. I think it is a simple one to fix, but would like some backup as I am a newbie at this.
    There was no moisture above the joint pictured (see below). You can see a water drop at the right hand side of a threaded section of pipe by a shutoff valve -- the handle is just out of the frame, but you can see the flexible supply line connection nut. Ignore the tilt of the picture -- it's the best I could do in a tight space.
    Anyway, it appears as though this is just a simple threaded joint. I removed the supply line and tried to tighten the (Brass Craft) valve onto the short stub of copper pipe, but I couldn't get it to budge. I was using a super short wrench, and I was kind of nervous to apply too much torque since I don't know what the h*ll I am doing -- it took several minutes for me just to figure out what kind of joint I was looking at. It seems as though I could just:
    - shut off the water supply to the house
    - open a hose spigot, which is lower than the joint in question
    - remove the supply line from the valve
    - remove the valve from the copper stub
    - clean the threads
    - apply a generous amount of pipe dope (maybe an insufficient amount was used originally?)
    - tighten the valve on again
    - close the valve
    - reattach supply line
    - close hose spigot
    - turn on water supply to the house
    - open up valve, try faucet & inspect the joint
    Is that right? what tools will I need? That is a super short stub of copper pipe to work with! Will I hurt the joint on the left where the copper stub goes into the 90-degree elbow when I do this?
    Any other advice is appreciated.
    Aug 2009
    South*East
    Replace the galvanized nipple with brass. You have a galvanized nipple between a brass valve and a brass fitting.
    John
    That is NOT a "copper stub", it is steel nipple. Remove it and replace it with a brass one. I didn't realize there were so many steps to take in order to remove it. We just usually turn off the water, remove the valve, and replace it.
    Plumber jimbo's Avatar
    For now, you could remove the line up to the faucet, and turn the valve another 1/2 turn onto the nipple. That might fix your leak.
    Oh, I didn't know if it's OK to just tighten it more or if it breaks the seal that the pipe dope is (supposed to be) making.
    And of course the other responders were right that it is galvanized steel and not copper -- I had forgotten that I put a magnet to the nipple to determine that, duh.
    Are brass nipples like that a standard thing I could just walk into a hardware store and buy? Are they generally about that length? Why should I use brass?
    Is a pipe wrench the right tool to use to tighten the nipple (and to hold it motionless when tightening the valve on it)?
    Seriously, guys, I appreciate any detail you can give (hence my "long list" of steps).
    You can use pliers or pipe wrenches. I do almost everything with pliers. I get a kick out of movies that show plumbers with giant pipe wrenches working on small fittings. sometimes on the wrong side of the fixture, the side with no plumbing.
    Brass is permanent. Galvanized steel will close up over time with rust. And placing steel between copper and brass just speeds up that process.
    Years ago I asked a plumber why the shop used galvanized.
    "It's a bit cheaper. Don't worry about it, it's a guaranteed service call later on."
    That was almost forty years ago.
    DIY scratch-pad engineer leejosepho's Avatar
    Nov 2006
    Quote Originally Posted by larryleveen View Post
    A "close nipple" is the shortest, and some will have flats for applying a wrench between the threaded ends. Wherever possible, it can be best to use a nipple you can tighten into one fitting before attaching the next rather than just putting all three together and tightening both connections from one end. And along with that, using a nipple with some "grip room" in the center can help make it possible to later remove that nipple without damaging its threads.
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
    Sep 2009
    Seattle. WA
    That shutoff valve looks suspiciously thin where the female pipe threads are supposed to be. I wouldn't trust a valve like that not to split when tightened down.
    For sure, I would remove the valve, clean the threads thoroughly, and inspect closely.
    You do NOT tighten the nipple into the valve. You apply sealing compoud to both threads then screw it slightly into the elbow, then screw the valve onto the nipple, THEN tighten the valve which will also tighten the nipple into the elbow. Pipe wrench, adjustable "Crescent" wrench, or pliers, whichever you have the strength to use will do the tightening. The nipple you have is 1 1/2" long, also called a "shoulder nipple" and they will have a brass one the same length. Oh, I, and many if not most, plumbers would change the other one at the same time.
    You do not really want any steel/iron in your supply lines. You may have used it because you were scared to try to solder things, but there are other choices that are essentially permanent, iron/steel is not. And, eventually when it starts to rust, you'll have rust streams in the sink or wherever that supply runs to.
    Well, I took the stop off and cleaned the threads of the steel nipple and wrapped them with teflon tape. When I looked in the female threaded end of the stop I saw some debris, which I realized was the end of the nipple that had crumbled. I hadn't noticed when I was cleaning and taping -- or maybe it was "wishful non-seeing" it. I put the stop back on anyway, and the supply line, but it leaks still -- possibly slightly more now. Looks like I have to replace the nipple. Name:  photo-1.jpg
    quote; Looks like I have to replace the nipple.
    That is what we told you to do from the start, but you may also have to replace the valve. I would NEVER remove one of those valves and then actually reuse it. That would usually be a waste of time.
    Aug 2009
    South*East
    I just don't understand why people take the time to find and post a question on forums and then don't take the advice they spent the time looking for.
    John
    Whoa there, guys. Don't jump down my throat here -- there's no call to be rude.
    I was advised by someone in the thread that I could just try to tighten the fitting. I figured that removing the pipe dope and teflon taping would be important. Nobody ever advised that the valve should be replaced before HJ _just_ mentioned it -- what's the problem with reuse or a brass valve, BTW? I am genuinely curious.
    My slow exploratory work was to "get the lay of the land" with something I am completely unfamiliar with. The fact that I didn't _yet_ replace the nipple doesn't mean I am ignoring advice. Also, not everyone has a work schedule or transportation situation that allows them to hit a hardware store after work. I'd never criticize you for proceeding slowly on a repair related to my field of expertise. Please don't take my slow pace as disrespect, and please be kind and patient with others. Thanks to all who have provided help. I truly appreciate it.
    Nov 2006
    Well, I took the stop off and cleaned the threads of the steel nipple and wrapped them with teflon tape ... but it leaks still -- possibly slightly more now. Looks like I have to replace the nipple.
    The brass one should do better, but there can be complications even there. Not all manufacturers use the same process for making all the parts, and I have had times when one brand of nipple and another brand of fitting just did not fit together well at all. Also, pipe dope and teflon tape are actually more for reduction of friction during assembly so the parts can mate well than for sealing...and the same principle appears in electrical and electronics work where wire nuts and solder merely maintain a solid mechanical connection. So, always only use plumbing parts that fit well, and then use something slippery while fitting them well!
  1. Advice for Newbie
    By cycler in forum Boiler Forum
    Last Post: 10-13-2009, 07:56 PM
  2. Newbie: Simple Question on Shower Handles
    By don't_know_how in forum Shower & bathtub Forum & Blog
    Last Post: 04-27-2009, 05:13 PM
  3. Well Newbie - Need some advice
    By ljvanbo in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-14-2007, 06:24 AM
  4. Plumbing newb seeks advice on rough-in
    By ktulu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-06-2006, 06:16 AM
  5. Inspection Please - Novice seeks your expert advice
    By AMorey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-27-2006, 02:07 PM
