Results 1 to 2 of 2
Thread: waste wye flat or rotated?
    DIY Junior Member waltsyd's Avatar
    Nov 2012
    Three Rivers, CA
    Default waste wye flat or rotated?
    If given either option, would it be better for a 3" closet waste wye coming into the main 4" waste line to be flat or rotated up some amount? I know that vents must be rotated up, but waste wyes? It seems like waste flow would be better if it was rotated up, but then again, perhaps the water would wash out too quickly. I'm curious if you have an opinion.
    It's not something I would normally consider in a layout for a toilet. Like you mentioned above, it's common to roll for a vent to be above the flowline of the pipe, but not done much for waste.
  1. flat tire
    By Hairyhosebib in forum Joke of the day
    Last Post: 08-09-2012, 12:19 PM
  2. Flat venting
    By cool buffalo in forum Plumbing Forum Discussion & Blog
    Last Post: 04-12-2011, 05:47 AM
  3. Flat Rate or T&M?
    By D'Brie in forum Plumbing Forum Discussion & Blog
    Last Post: 10-02-2009, 07:59 AM
  4. Flange rotated about 5-10 degrees
    By dzarn in forum Toilet Forum discussions
    Last Post: 11-03-2008, 05:27 AM
  5. Gas pipe joint has rotated--leak?
    By MBrown in forum Plumbing Forum Discussion & Blog
    Last Post: 11-21-2004, 06:13 PM
