Results 1 to 10 of 10
Thread: Recommendations on Acid Neutralizers
    DIY Junior Member wvaleries's Avatar
    Dec 2012
    Virginia
    Default Recommendations on Acid Neutralizers
    We currently have a Water Right Sanitizer Plus Series water softener in our 2-3 bath house. Our water was tested recently and the ph level was 6.5, iron 3.5, and hardness 12. We've been told that we need a 1.5 cu ft acid neutralizer installed. I have several questions. Does it matter what brand (any recommendations - we'd like to keep costs down as much as possible)? Calcite vs. mixed bed? Is this something that we can install ourselves? Thanks for any help you can give!
    DIY Senior Member Bob999's Avatar
    Jul 2009
    Pennsylvania
    A backwashing filter with a Fleck 7000 control head is my recommendation. With pH of 6.5 Calcite (only) is indicated.
    I recommend at least 2 cubic ft of media and 2.5 is preferred for higher flow rates provided your well/pump can provide the required backwash rate.
    Installation involves making the plumbing connections (prior to the softener) for inlet, outlet, and a drain connection. You also need an outlet for the control-Time Clock is appropriate for AN filters.
    Here is one internet supplier (there are many others) so you can see a representative range of sizes/prices along with required backwash rates:
    http://www.ohiopurewater.com/shop/cu...me.php?cat=212
    Nov 2010
    Maine
    I second Bob's motion. Good to see another 7000 fan on board. It's become the only valve I stock anymore.
    we off the Fleck 7000 acid neutralizer for 695.00 shipped to you, go to www.midatlanticwater.net
    Default 13x54 acid neutralizer
    Quote Originally Posted by wvaleries View Post
    we currently have a water right sanitizer plus series water softener in our 2-3 bath house. Our water was tested recently and the ph level was 6.5, iron 3.5, and hardness 12. We've been told that we need a 1.5 cu ft acid neutralizer installed. I have several questions. Does it matter what brand (any recommendations - we'd like to keep costs down as much as possible)? Calcite vs. Mixed bed? Is this something that we can install ourselves? Thanks for any help you can give!
    your better off going with a 13x54 acid neutralizer you will get better contact timee with the media during peak water usage and you wont have to svc it as odten as the 10x54 unit
    aidan
    mid atlantic water
    888 299 7479
    www?midatlanticwater?net
    What size pump does he need to successfully backwash that size AN filter?
    Nov 2010
    Maine
    Ah the rite of initiation. All must pass the scrutiny of The Lord of filtration before offering advice. Lol.
    Ignore him 6266 or forever be drawn into the never ending cycle of abuse.
    However the answer to the question is............ Big enough lol
    Jan 2012
    California
    Agreed, but... to answer the question...
    Calcite should be backwashed at 8-12 GPM per Sq. Ft. of bed area. A 13" diameter tank would therefore require approximately 10 GPM to properly backwash.
    πr² / Sq. Ft. x recommended backwash rate
    6.5 x 6.5 x 3.14 / 144 x 10 = 9.2 GPM
    The fact is that many residential submersible or jet pumps are not capable of that flow rate. And anyone offering advice to someone about the size of heavy mineral filters should mention the flow rates required to backwash the size of the filter they suggest, or sell. The well must be capable of delivering that gpm for the total length of time of the backwash and then just a minute or so later the gpm for the rinse cycle. Some wells will not be able to do that. And the larger the filter, the longer the backwash and rinse positions run for and you can get into a couple hundred gallons in just 20-30 minutes. A 6" diameter well has 1.47 gal per foot of water in it. That's from the static water level down to the inlet to the pump, not the total depth of the well.
    And good buddy Tommy, that helps the guy avoid failed equipment and having call backs and unhappy customers.
    Nov 2010
    Maine
    Golly Wally, I'll bet he didn't know that lol.
  1. acid neutralizer
    By devans175 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-19-2010, 08:05 AM
  2. Acid wash?
    By HoneySuckle in forum Remodel Forum & Blog
    Last Post: 10-30-2007, 01:21 PM
  3. Acid tablets?
    By lardlad in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-05-2007, 06:48 AM
  4. acid bath
    By slevota in forum Plumbing Forum Discussion & Blog
    Last Post: 10-27-2006, 05:53 AM
  5. Acid the way to go ?
    By Wants to Know in forum Irrigation / Sprinkler Forum
    Last Post: 05-19-2006, 07:17 AM
