- Messages
- 33,603
- Reaction score
- 1,042
- Points
- 113
- Location
- Cave Creek, Arizona
- Website
- www.terrylove.com
frost
It is hard to follow your "logic". But it the pipe is buried below the frost line, then the discussion is immaterial. If it is above that point, then regardless of what you wrap the pipe with it is eventually going to reach the same temperature as the surrounding ground. It has nothing to do with where the frost line is. Insulation, of any kind, does not prevent freezing, is merely slows the process down until, hopefully, events will occur to reintroduce "heat" to the pipe so it does not freeze. If the liquid in the pipe is static for a long enough period, or enough liquid is not sent through the pipe to "warm" it up, the liquid is going to freeze eventually.
