Results 1 to 2 of 2
Thread: copper "soft" pipe used as part of gas hookup?
    DIY Junior Member josef's Avatar
    Mar 2012
    atlanta
    Default copper "soft" pipe used as part of gas hookup?
    Hey everyone,
    I was at my mothers checking out her electric water heater that had started to leak and made a mess in the crawl space. Didn't think it was that big a deal and ran out to get a new water heater, yada yada.
    While in the crawlspace I noticed that the gas line to the furnace and oven was made up of black pipe and soft copper pipe sections. It looked like someone moved the furnace from an old spot, and then tied into the new spot with copper instead of black pipe.
    Is this legal/safe/etc? I live in ATL georgia, and we use IPC 2006 w/ ammendments for atlanta. Do I need to call a plumber out asap to replace that copper with black pipe or is it ok? Thanks,
    Josef
    It depends on your gas and how it was connected. Some gas is corrosive to copper, and the only "safe" connections are flared fittings or brazing. It can NEVER be soft soldered.
  1. Connecting 1/2" copper to old 3/4" brass pipe
    By sean farrell in forum Plumbing Forum Discussion & Blog
    Last Post: 06-08-2012, 12:46 PM
  2. "play" in copper pipe
    By rmc115 in forum Plumbing Forum Discussion & Blog
    Last Post: 01-10-2012, 08:37 PM
  3. Draining Copper Pipe Causes Corrosion? "Old Wives Tale" or ?
    By dayster in forum Plumbing Forum Discussion & Blog
    Last Post: 03-07-2011, 04:51 PM
  4. Is It Okay To Spray "Great Stuff Foam" Around Copper Pipe and Copper Fittings?
    By turbocruiser in forum Plumbing Forum Discussion & Blog
    Last Post: 11-01-2010, 11:57 PM
  5. How to solder a "T" in copper pipe?
    By rsmith99 in forum Plumbing Forum Discussion & Blog
    Last Post: 04-14-2008, 05:29 AM
