Results 1 to 6 of 6
Thread: Hot Water Flow to Shower Issue
    DIY Junior Member Jeff Bailey's Avatar
    Dec 2012
    Mississippi
    Default Hot Water Flow to Shower Issue
    When the shower is going, suddently there will be a very noticeable and cold reduction in water pressure and hot water. Obviously, the loss is from the hot side. No other showers/baths/or water used at the same time. In fact, it happens when the shower is used before anyone else.
    The flow will cut back on after about 30 sec, but it won't be near as hot as when the shower started. Crazy. Need help
    Jan 2008
    You have a tankless water heater?
    Dec 2012
    Mississippi
    Default No
    Reg. gas-fired HWH. About 4 Y/O
    Jan 2008
    Then the problem is likely to be the pressure/balancing/anti-scald valve inside the shower valve.
    You have a problem that needs someone there to check it while it is happening. You do not have enough information for us to make a diagnosis. If you have a circulation system, then a bad check valve would cause those symptoms, but turning on the hot water in a sink would change the water back to hot again. But this is only one possibility among many.
    Dec 2012
    Mississippi
    Default This is what I'm thinking, too
    If this IS the prob, will it get worse? I can live w/this but if its gonna get worse, I pretty sure I'm gonna get it fixed over the holidays
  1. Flushometer Low Flow Issue
    By Robert Walser in forum Toilet Forum discussions
    Last Post: 11-03-2010, 02:35 PM
  2. Expansion tank and regulator back flow pressure issue
    By IAMIR in forum Water Heater Forum, Tanks
    Last Post: 07-04-2010, 01:42 PM
  3. Hot water issue in the shower
    By luvmy2gals in forum Shower & bathtub Forum & Blog
    Last Post: 01-24-2008, 10:03 AM
  4. Hot water issue in shower/tub
    By nelsonba in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-18-2006, 08:04 AM
  5. Shower hot water issue - hot from tub faucet, lukewarm from shower head
    By mikea128 in forum Shower & bathtub Forum & Blog
    Last Post: 09-29-2006, 06:37 AM
