Results 1 to 6 of 6
Thread: venting through the wall?
    DIY Junior Member Philbert's Avatar
    Aug 2010
    Toronto,Ontario,Canada
    Question venting through the wall?
    I would like to move a sink in the basement I know that inspectors prefer the venting to be through the roof but in this case it isn't practical, so can it go through the wall so long as it a) is above the floodline and a min of 3" pipe as it exits to the outside to avoid it from freezing shut. I am in Ontario, Canada
    Thank you
    The local inspector would know. We run vents on the outside and through the roof sometimes here. And of course much of the older Seattle homes have the plumbing outside the walls.
    Those all go through the roof under the eaves and are at least six inches higher then the roof. More like 12"
    Vents can't daylight under a window.
    The whole idea is to get the venting up high where the winds can blow it "away" from your home.
    Aug 2010
    thank you very much
    DIY Junior Member shortcuttomoncton's Avatar
    Nov 2012
    Ontario
    Yeah, my sister in law recently did this in Toronto. Straight out, and up and around the eave.
    If you intend to just stick it out of the wall, then NO. If you will turn it upward and go above the roof, then "maybe" if you can convince an inspector that even the larger size will not freeze over because of its length. The inspectors don't "like" vents through the roof, most codes INSIST on it, so it makes no difference what the inspectors "like".
    Aug 2010
    I just obtained a copy of the 2006 Ontario Plumbing code and once I decoded the relevant section (7.5.6.7 part 4) I found that allows so long as it exits the wall at a maximum of 45 degrees and is atleast a 3" pipe size as well as some minimum clearance requirements for windows, doors, ground and fresh air inlets .
  1. Venting Through an Outside Wall
    By APryde in forum Canadian Plumbing Code Questions
    Last Post: 07-28-2011, 06:18 PM
  2. Venting a tub 6' from any wall, UPC
    By zachr in forum UPC Plumbing Code Questions
    Last Post: 07-10-2010, 08:25 PM
  3. Venting a tub 6' from any wall, UPC
    By zachr in forum Plumbing Forum Discussion & Blog
    Last Post: 07-10-2010, 06:24 PM
  4. Thru wall venting concern
    By Grinbau in forum Plumbing Forum Discussion & Blog
    Last Post: 05-07-2006, 04:28 AM
  5. Venting through wall
    By Scott Peters in forum Plumbing Forum Discussion & Blog
    Last Post: 04-18-2006, 10:58 AM
