Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: mountain bathroom
    DIY Junior Member Riley746's Avatar
    Dec 2012
    colorado
    Default mountain bathroom
    I'm rebuilding an outbuilding to a Colorado mountain cabin. I want to make it into a bedroom with a bathroom. The structure is on concrete piers and there's no crawl space. I'll hire a plumber but I'm wondering if my design will work. The bathroom is on an outside wall. I'm going to build two 2x6 walls, one insulated and the other for plumbing. I want to put in a clawfoot bathtub, toilet, and sink. If I use a TOTO wall hung CT418FG with a Geberit 111.728 carrier sytem can I run the septic in the interior wall with the water? Can I vent the toilet out the end wall? Please see sketch.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Please be sure to vent properly !
    Then run drain pipe out back wall and let run down side of mountain
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Yakima WA
    Macplumb, surely you are not suggesting he just let the sewage for the toilet "run down the side of the mountain"? This not India, it's Colorado, USA and we don't just dump sewage down the side of our mountains! Maybe (I hope) you just haven't explained yourself too well.
    Dec 2012
    colorado
    The toilet will run to a septic system. My question is can I run the pipe from the toilet horizontally in the inside wall?
    You will want to vent the tub, the toilet and the lav.
    The lav can wet vent the toilet.
    The tub vent can tie into the other vent(s) at 42" above the floor. If you run the vent out the side wall, you will then need to extend through the roof.
    Water and DWV is normally done in the same wall. Having a wall of insulation behind the plumbing is a good idea. To keep the trap for the tub above the floor, (that's what you are intending?) you will need to raise it. Otherwise the trap is installed below the floor, with just the slip joint nut extending above the floor.
    Dec 2012
    colorado
    The tub sits on legs so it's 4 3/4" above the floor. Can I run the drain along the floor to the wall and then use an elbow to run it inside the wall?
    I realize that the tub is on legs, but you also have a waste and overflow, and that connects to a p-trap.
    The p-trap below the tub waste is going to take up some space.
    And you will need the p-trap unless you don't mind smelling your septic tank odors.
    A vent for a tub p-trap is typically within 42"
    More then likely, the p-trap will have to be below the floor.
    Dec 2012
    colorado
    So I could run it to the wall and put the trap in a chase, insulate the chase, and then run the pipe horizontally to the sewer connection?
    Jan 2008
    The trap will be at the bottom of the waste and overflow assembly, so it will be below the floor. You could box it in below the floor with an insulated chase and run heat to the chase. From the trap the drain will have to go towards a wall so that the vent take-off can rise vertically up the wall to go out the roof.
    A cold, windy environment will freeze things up if there are any air leaks, regardless of the insulation so you must be quite meticulous in doing your walls and insulation plus air sealing. you won't be able to turn the heat down either without winterizing things which means draining what you can and filling the traps with RV antifreeze. Make sure to install your water lines with some slope so you can drain them down well. The only thing in a drain that should be at issue are the traps, and those will need the antifreeze. Keep in mind the insulation only slows the movement of heat, it doesn't generate any. There's no such thing as cold, only the absence of heat. Since this building is up on piers, you must pay close attention to the water supplies and have a reliable source of heat, or provide for some means to drain or blow them dry. You ight consider pex - the tubing itself is unlikely to split if it freezes, but connectors will, so where they are placed is critical.
    Dec 2012
    colorado
    I have one more question. I'm going to use a gas tankless Rinnai for a water heater. The propane comes in by the water. I'm going to panel the room with beadboard Can I recess the Rinnai in the 6" interior wall at the end of the tub so the vent goes through the ceiling in the interior wall and only the face of the Rinnai extends beyond the panelling? Also is there any problem putting it up above the end of the tub?
    Thanks for the cold comments. We use this year around so we'll keep low heat on in the bathroom.
    Each unit will have some very specific clearance requirements, then you have to consider maintenance (and a tankless will require typically annual cleaning to remove mineral deposits so you'll want to include the isolation valves and purge points for that). All of that may make it impractical to recess the unit even if allowed. Now, assuming it is a condensing unit that uses pvc for venting and air intake, that can make at least a few turns (each turn decreases the maximum linear flue it can support but it sounds like you should have enough). If it isn't condensing, then the flue will have bigger issues about clearance to flamables. You should download and read the installation manual for the model of interest and that will tell you what is allowed. Note, local codes may differ, but usually follow the installation manual from the manufacturer.
    There are two places they don't allow gas water heaters. Bedrooms and bathrooms.
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    What about a completely sealed, direct vent unit?
    I somehow convinced myself once they may be allowed in bathrooms, under certain conditions...
    A "sealed direct vent" heater, since it does not use room air for combustion can be installed in bedrooms and bathrooms. Your tub trap will be partially depressed through the floor, but most of it will be above the floor because its outlet will have to be at the height of your drain line, and if you do some measuring, I think you will find that the tub is TOO low for an above the floor horizontal drain line. The tub may be 4 3/4" above the floor, but drain "shoe" will be about 3 3/4", subtract from that the "end to center" of the drain tee, and you will be just about at the floor level, meaning, that if you can somehow get it connected to your horizontal drain line, it will usually stand full of water and thus have poor drainage.
  1. Skiing at Crystal Mountain, WA
    Last Post: 05-05-2013, 06:52 PM
  2. The Mountain on Vimeo
    By Cookie in forum Health and Wellness Forum
    Last Post: 05-29-2011, 10:17 AM
  3. Crystal Mountain April 15th
    Last Post: 04-17-2009, 09:26 PM
  4. Mountain Electric
    By Southern Man in forum Electrical Forum discussion & Blog
    Last Post: 08-15-2008, 07:31 AM
  5. New mountain cabin
    By nova202 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-15-2006, 02:49 PM
