Results 1 to 1 of 1
Thread: Something new to me - Water Trash Pumps
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default Something new to me - Water Trash Pumps
    I'm in full Post Prep Sandy Mode....adding various things here and there.
    Something new to me are Trash Pumps.
    For starters, the low point in my house tends to overflow..
    Unfortunately for me, my newly installed check valve did now work this year...
    What I had done last year, was to use a surface pump to pump water into the tub.
    From the tub, I had a Zoeller Sump sitting in there pumping water out.
    A pit/etc is not really a option. It's a finished basement...
    Fast forward.
    With the Sump, the pump's power is just doing the pumping direct
    I'm curious. For water trash pumps, aside from a bigger engine/bigger inlets - how much SUCTION/PUMPING power is lost due to it doing 2fold - both suction and pumping from a distance. I'm not going to run this indoor - due to gas engine, but I am curious is it more powerful than than the Zoeller if I am running the suction from these types of pumps about 50 Feet Away (20 feet away from the house/30 feet to the tub) + the pumping is alot shorter since the engine is pretty much outdoors already.
    EDIT - POST Posting this
    Not going to work for my application.....as I would have preferred to buy and use a flat hose (just due to space).
  1. Shallow Well and a Trash Pump
    By muddydawg in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-09-2010, 06:17 AM
  2. Should I trash or save this assembly?
    By cmw in forum Plumbing Forum Discussion & Blog
    Last Post: 09-05-2010, 07:30 AM
  3. Water-powered sump pumps
    By jumpyg in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-12-2008, 06:04 AM
  4. advice on hot water recirc pumps
    By barrybpdx in forum Plumbing Forum Discussion & Blog
    Last Post: 04-27-2007, 09:47 AM
  5. Trash pump?
    By price914 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-04-2007, 04:14 AM
