Results 1 to 3 of 3
Thread: Pilot Light Stays Lit Yet Hot Water Does Not Come On
Hybrid View
    DIY Junior Member ghatfuswow's Avatar
    May 2012
    homwe, Oklahoma
    Default Pilot Light Stays Lit Yet Hot Water Does Not Come On
    I have a Bradford White water heater model# MI40T6FBN with an electronic Honeywell gas control knob.
    At first, I was having issues with the pilot light not staying lit, so I went out and replaced the pilot assembly. Now that I've done this, the pilot light will stay lit, but I don't get any hot water.
    What might be wrong?
    The pilot light heats up a sensor - that sensor must be properly positioned and clean to produce the signal that tells the WH it's okay to turn on the main burner. Replacing the pilot light assembly may mean the flame size or position isn't correct to heat that sensor (a thermocouple), thus, the WH thinks it is unsafe to turn on the burner. If that isn't it, it's either the thermocouple, the gas valve itself, or you didn't turn the valve to operate, and it's still on pilot.
    May 2012
    homwe, Oklahoma
    I ended up placing a call to tech support.
    They told me to pull the cover off the combination gas valve/thermostat (there's a single screw on the lower left of the cover) to reveal three pins. I was then to measure the resistance between the center pin and the left pin and then the center pin the right pin. From there, if my reading on both measurements was not 12-13ohms, it would indicate the combination valve/thermostat is bad.
    I did do the measurement and it looks like the valve is bad; my center to right reading yielded an open.
    Now I have to figure out how to remove the combination gas valve/thermostat. Not sure how to go about it since the manual only covers removal of the White-Rogers gas valve/thermostat.
  1. Pilot light is lit and stays lit but will not flame up to heat water
    By tamaram in forum Water Heater Forum, Tanks
    Last Post: 12-10-2011, 12:01 PM
  2. water heater pilot light problems
    By scorch in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-17-2008, 03:59 AM
  3. Water heater pilot light goes out
    By Coldnwet in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-09-2008, 01:45 PM
  4. water heater pilot light issue
    By Ruger in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-13-2007, 04:32 PM
  5. Pilot won't light on Reliance 501 Water Heater
    By HarmonyRose in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-27-2005, 03:22 PM
