Results 1 to 5 of 5
Thread: Odd faucet stem help
    DIY Junior Member MIHillbilly's Avatar
    Dec 2012
    MI
    Default Odd faucet stem help
    My house was built in the 60's and I assume original 3 handle bathtub faucet. "Standard" "Made in USA" is stamped on the drain lever cover. I can remove the handles and escutcheon and the packing nut with a 5/8" wrench. I see a larger hex nut behind that. The packing nut was screwed into that larger hex. However that larger nut is rexessed about 1/4" in a thick sleeve. The points of the hex are flush tight with the sleve ID. A flat blade screwdriver will enter between the hex flats and sleeve ID. The sleeve is too far into the wall to grab on the OD. I can see all the way back on the sleeve OD and there is no hex feature for a socket. I tried backing the stem out throught the packing with no luck. Do they make a socket with tabs or ears to engage the hex flats inside the sleeve. Or is there another solution.
    Thanks for any help.
    In the Trades Towers Plumbing's Avatar
    Nov 2012
    Salt Lake City, UT
    If it is an American Standard brand, then all three styles from that era have a spot to put a wrench on to remove the entire stem. As would Price Pfister. However, without a picture, or something to look at, all we can do is speculate.
    A picture would help, but in almost ALL cases, the sleeve unscrews first. "Standard" on the drain cover has absolutely NOTHING to do with the brand of the faucet.
    Dec 2012
    MI
    Photo attached
    Dec 2012
    MI
    Any takers now that a photo is attached. The packing nut is removed in the photo.
  1. leaking faucet stem
    By giwatcher in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-28-2011, 08:14 PM
  2. Faucet stem unscrews, but won't come out
    By Seawolf in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-29-2009, 10:57 PM
  3. Help UFS Unidentified Faucet Stem
    By dbailey75 in forum Shower & bathtub Forum & Blog
    Last Post: 12-12-2006, 10:06 AM
  4. Removing and replacing tub faucet stem
    By jono in forum Shower & bathtub Forum & Blog
    Last Post: 10-07-2005, 11:22 AM
  5. relpacing stem/core on faucet
    By jackman691 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-22-2005, 08:03 PM
