Results 1 to 3 of 3
Thread: adapting sink drain from 1/14 to 1 1/2 at trap
    DIY Junior Member lemon00's Avatar
    Dec 2012
    Seattle
    Default adapting sink drain from 1/14 to 1 1/2 at trap
    I have a threaded sink drain that requires a 1 1/4" flanged tailpiece. the trap that is installed is a 1 1/2" slip joint (ready to accept a 1 1/2" pipe). It seems to me the easiest way to deal with this is to have an adapter at the p-trap, that will accept a 1 1/4" pipe I know there are 1 1/4" to 1 1/2" adapters, but all the ones I can find are a weld-type on the 1 1/2" side. Are there ones that are threaded on the ! 1/2" side, so I could just take the nut off the slip joint on the trap, and screw on the adapter? Or how else can I do this?
    You use a 1 1/2" x 1 1/4" slip joint washer inside the slip nut.
    Dec 2012
    Seattle
    ahh so simple thanks!
  1. Trying to connect drain tailpipe to the trap in a bathroom sink.
    By slinky in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-22-2011, 02:19 PM
  2. Length from sink drain opening to p trap
    By Corgilvr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-13-2011, 08:02 PM
  3. Connecting plastic sink drain to metal p trap
    By DIYhell in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2010, 02:09 PM
  4. Kitchen sink drain and trap
    By shawnkey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-16-2007, 09:35 AM
  5. S Trap / vanity sink drain / vent
    By DOPeter in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-16-2007, 05:56 PM
