Results 1 to 3 of 3
Thread: Watts Quick Connect / John Guest style fittings... proper installation?
    DIY Member Killer95Stang's Avatar
    Mar 2012
    Southern CA
    Default Watts Quick Connect / John Guest style fittings... proper installation?
    I just need to make the final connections on my Reverse Osmosis system. Kit I purchased included John Guest type quick connect fittings for the plastic tubing (polyethylene). The tubing that was supplied is color coded and seems to be little stiffer (holds it shape better) than the translucent clear tubing that you find at the hardware store. When I've made compression connections in the past, I always used the brass or plastic anti-crush tubing inserts. Do I need to use them or is it a problem if I use the with the quick connect type fittings?
    Thanks..
    John Guest fittings do not use the ferrule, at least not on the smaller sizes.
    Mar 2012
    Southern CA
    Thanks... installed without the inserts and so far no drips....
  1. Need help identifying part - faucet quick-connect hose
    By desparate_geek in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2011, 01:57 PM
  2. watts or zurn pex fittings
    By Master Brian in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-21-2008, 09:59 PM
  3. Watts quick-connect fittings?
    By Rancher in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-18-2008, 07:07 AM
  4. Pfister - Removing quick connect HELP
    By JeffH in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-14-2006, 04:55 AM
  5. Watts - Quick-Connect
    By mmcgady in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-28-2006, 03:07 PM
