Results 1 to 6 of 6
Thread: Drop in frame for whirlpool
    DIY Junior Member clapfc's Avatar
    Nov 2012
    albany ny
    Default Drop in frame for whirlpool
    OK, this is my first drop in frame.
    Water damaged sub-floor repaired, joists reinforced with blocking, even put sound proof insulation down.
    Now I have a question on the correct height for the drop-in tub.
    Here it goes.
    Height of the tub deck is 19", lip edge is 2" so the height from the floor to deck lip edge is 17". Now for the vertical frame calculation using 2x4s: Bottom plate 1 1/2, top plate 1 1/2, plywood 3/4, cement board 1/2, tile & mortar 1/2, vertical 2x4s at 12 1/4. This gives me a height of 17". Bottom of deck lip edge is 17" so I should be good, right? (1 1/2, 1 1/2, 3/4, 1/2, 1/2, 12 1/4, = 17) What I did not calculate is the mortar bed the whirlpool will sit in. Do I add another inch for the mortar bed? Meaning the height to the deck lower lip would be 18" and my frame needs to come up another inch? Or do I ignore the mortar bed with the idea that pushing down into the bed will displace enough mortar to make the bottom of the whirlpool practically sit on the sub-floor. The whirlpool is a jacuzzi primo if that matters. comments &/or suggestion appreciated.
    questions:
    1. Am I building to the correct height?
    2. Do I mortar & tile after setting the tub in mortar bed or before? (current plan is to set in mortar bed first & use 1" scrap wood to leave space for the cement board & tile & mortar.
    CLAPFC
    Jul 2009
    North Vancouver, BC
    If you can tile the tub deck first that is dream. Then your life will be easier.
    If you want to tile after then 5/8" spacers work well for 3/8" tile and 1/4" thin-set.
    The mortar mix under the tub should be higher than needed. The tub set overtop and squished down to resting position. The tub should sit on it's feet and the mortar mix serves as only bonus strength between the feet.
    We use poly to keep the mortar from bonding to the tub.
    Just installed one yesterday.
    I'll look for the pics.
    JW
    Jul 2009
    North Vancouver, BC
    Here you can see the tub sitting out in the room over some Ditra. There is about 2"-3" of space under the tub when it's resting on it's feet.
    My mortar mix mixed fluffy and sitting nearly double the height I need.
    I have the mix in the middle away from the feet of the tub.
    Then a double layer of light weight poly and the tub goes in over top.
    From the face and sides I can push the poly back and pack the mortar mix.
    All good.
    JW
    Pictures look good John. Mine didn't require mortar though, some do not.
    Nov 2012
    albany ny
    JW, thank you for the response and the pics. I get nervous when measurements have to be exact especially the first time I am doing something. This really helps. Gives me confidence I am on the right track. Did not think about the poly, I will incorporate that into the project. Pics really helped. Thanks again
    CLAPFC
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by clapfc View Post
    Your welcome.
    The poly is key. Once you set that tub run it through it's paces. If you need to remove it because of a leak you will be glad the tub is not stuck to the poly. The poly is a bond breaker here.
    The mortar mix does not hold up the tub but only prevents it from sagging in the middle. It will feel more solid this way.
    JW
  1. Drop in frame for whirlpool
    By clapfc in forum Toilet Forum discussions
    Last Post: 12-04-2012, 07:30 AM
  2. Drop In Whirlpool
    By dotwari in forum Shower & bathtub Forum & Blog
    Last Post: 05-15-2008, 08:38 PM
  3. Drop-in Whirlpool
    By Bob1234 in forum Shower & bathtub Forum & Blog
    Last Post: 04-16-2008, 06:13 PM
  4. drop in whirlpool
    By bigun471 in forum Shower & bathtub Forum & Blog
    Last Post: 08-14-2006, 08:21 PM
  5. Drop-in Whirlpool Tub install
    By rdtompki in forum Shower & bathtub Forum & Blog
    Last Post: 03-10-2006, 11:30 AM
