Results 1 to 7 of 7
Thread: Lav plumbing question
    DIY Junior Member r0bh3's Avatar
    Dec 2012
    Massachusetts
    Default Lav plumbing question
    Hello, I've been lurking for a while and now it's time to tackle a project of my own.
    I would like to locate a Lav in this space. I would like to run the vent vertical in the wall to the left of the window. Question is, can I get there with the trap arm? Can there be a 90* bend in the trap arm and can it extend roughly 60"?
    The plan is to have the plumbing concealed under that window with a short wall then it will enter the vanity console from the side.
    A 1.5" lav drain can be 42" to the vent.
    You can go 60" with a 2" trap arm.
    What you are trying there looks a bit dicey. I can't think of seeing it done that way in the last 38 years of plumbing. I would move the plumber closer to the lav drain.
    Dec 2012
    Massachusetts
    Thanks Terry, I guess I thought I was 'pushing' it a little with this design, hence the reason for the question. You say, move the plumber closer to lav drain, do you mean the vent fitting?
    Yes, the vent fitting.
    Plumber jimbo's Avatar
    Quote Originally Posted by r0bh3 View Post
    I think terry means move the waste pipe closer...not necessarily an easy DIY job. Besides the vent issue...which you could deal with by taking off a vent and running it up and above the window....you would have potential clogging issues with a long trap arm. Unless you were very careful to have slope....assuming you used a 2" drain and it did not exceed 60" then you would have to drop an inch and a quarter . A plumber looking at your house ( the parts we can't see!!) might have better ideas.
    Dec 2012
    Massachusetts
    Understood, thanks for the replies.
    I know these drawings aren't great but here is a little more info. 3" main waste line runs here just under floor in basement, there is a WC about 4' downstream from where I want to tie the Lav drain in, and a shower drain about 1' upstream. Would adding a vent where the yellow line, running it up and over ceiling and tying into existing vent in attic help at all?
    Yes, but then you would NOT need the "red one" on the left side of your drawing.
  1. Plumbing question- PEX
    By new_home_owner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-30-2009, 06:06 AM
  2. Plumbing question
    By catk9 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-23-2007, 12:24 PM
  3. Plumbing question
    By HoneySuckle in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-14-2006, 05:04 AM
  4. CI Plumbing Question
    By brody-o in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-06-2006, 02:14 PM
  5. Tub plumbing question
    By ppitts in forum Shower & bathtub Forum & Blog
    Last Post: 07-04-2005, 01:48 PM
