Results 1 to 2 of 2
Thread: Connect to main
    DIY Junior Member Hammer8789's Avatar
    Dec 2012
    McHenry, Il.
    Default Connect to main
    We are having an irrigation system installed. The plumber is here connecting to our main line. What he has done is nothing like I have ever seen, though he says it will be fine. We are on a well so my main runs in with a 1" pvc flex to the baffle/pressure tank. comes out with 1" galv. pipe and reduces to a 3/4' valve then feeds the house. He has cut the 3/4' line after the valve and installed a 3/4 x 3/4 x 1" T. The 1" is what he is running to feed the irrigation system. I would have removed the reducer, replaced the 3/4" valve with a 1" then installed a 1"x 3/4"x 1" T and moved on. It just doesn't seem right to feed a 1" pipe with a 3/4 ". Who is right?
    A small section of 3/4" isn't going to have much effect.
    With city water, the setters are 5/8" or 3/4", and we run 1" or 1-1/4" off of those.
    A long distance of 3/4" would have been more of a worry, the distance adding to the friction loss.
    If you look at a hosebib, the port that the water comes through is very small. And yet it will gush out of there.
  1. Replies: 8
    Last Post: 11-06-2012, 09:05 AM
  2. Connect apartment to main house well?
    By DIY Ray in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-08-2012, 07:37 AM
  3. Best way to connect PVC to Galvanized?
    By burleymike in forum Plumbing Forum Discussion & Blog
    Last Post: 07-11-2010, 08:20 PM
  4. Are these Concrete? How do I connect PVC?
    By froddan in forum Plumbing Forum Discussion & Blog
    Last Post: 07-11-2007, 05:06 PM
  5. How to connect (wordy)
    By billonion in forum Remodel Forum & Blog
    Last Post: 12-30-2005, 10:59 AM
