Results 1 to 8 of 8
Thread: venting 2nd floor bath
Hybrid View
    DIY Junior Member bwc's Avatar
    Dec 2012
    NB
    Default venting 2nd floor bath
    I am adding a new bathroom on the second floor. Can I tap into the vent from the first floor bath in the attic so to save from putting another vent through the roof? The horozontal distance is about 15'. If so, can I do it with 1 1/2" pipe (ABS)?
    You can tap your 2nd floor vent into that. You can NOT put any WASTE into that vent line from the first floor. Your second floor vents cannot be horizontal ( less than 45 degrees) until 42" above the floor, and must ALWAYS have some minimum continuous slope back towards the drain, to avoid bellies which would fill up with rain water
    Oct 2011
    see if this helps, what size is the vent going thru the roof? 3"?
    Dec 2012
    NB
    Thanks. That is helpfull
    Jan 2008
    If you are running a new vent through the roof you will also want to look at your local code. Many places will not allow a vent smaller than 3 or 4" to penetrate the roof due to the possibility of frost closure during the winter.
    In the Trades SacCity's Avatar
    Mar 2011
    Sacramento, CA
    If you are going to have a toilet in the bathroom, min vent size is 2 inch
    Michael
    Sac City Plumbing
    http://SacCityPlumbing.com
    Nov 2010
    Maine
    Quote Originally Posted by SacCity View Post
    Only if he's under the UPC. Under IPC it can be 1-1/2 and it doesn't even have to be in the same location as the WC
  1. no bath venting?
    By marciaggg in forum Plumbing Forum Discussion & Blog
    Last Post: 09-04-2011, 12:29 PM
  2. Need advice on venting 2nd floor bath
    By adthern in forum Plumbing Forum Discussion & Blog
    Last Post: 06-02-2010, 10:08 AM
  3. Bath exhaust fan venting
    By dabiz7 in forum Remodel Forum & Blog
    Last Post: 10-04-2009, 02:42 AM
  4. Q re venting basement bath
    By Soke in forum Plumbing Forum Discussion & Blog
    Last Post: 04-26-2007, 03:54 PM
  5. venting my new attic bath
    By Don in forum Shower & bathtub Forum & Blog
    Last Post: 12-28-2004, 05:50 AM
