Results 1 to 5 of 5
Thread: Water Supply Lines for Bathroom
    DIY Junior Member KShirriff's Avatar
    Nov 2012
    Tuscaloosa, Al.
    Default Water Supply Lines for Bathroom
    I need to run water to the 2nd floor bathroom. Should I run 3/4" up from the basement and reduce down to 1/2" for my connections or just branch off of the 3/4" in the basement and run 1/2" up to the bathroom?
    1/2" for hot and
    3/4" for cold and then branch with 1/2"
    Nov 2012
    Tuscaloosa, Al.
    so 1/2" for hot all the way up to the 2nd floor and 3/4" for cold up to the second then branch with 1/2"
    That MIGHT be what I would do with copper, but not with PEX.
    There's good and bad for going with smaller hot lines - unless you're running a recirc system, the smaller line means less waste while waiting for hot. But, 1/2" pex is closer to 3/8" copper in its ability to transport water. This may be okay for a single showerhead, toilet, or sink, but not for two at a time, or for filling a tub.
    If you go with a manifold system in the bathroom, get one with at least one extra port and use it to run a return line should you want to add a recirculation system.
  1. Flexible (roll) copper for bathroom supply lines?
    By Flot in forum Plumbing Forum Discussion & Blog
    Last Post: 09-22-2010, 06:09 PM
  2. heights for supply and drain lines for bathroom sink
    By Steve_P in forum Plumbing Forum Discussion & Blog
    Last Post: 09-21-2010, 01:27 PM
  3. Branching off water supply lines
    By JMichael in forum Plumbing Forum Discussion & Blog
    Last Post: 09-05-2010, 01:37 AM
  4. Need help with supply lines to bathroom
    By redgreen in forum Plumbing Forum Discussion & Blog
    Last Post: 05-24-2008, 02:30 PM
  5. Water Supply Lines
    By slodog in forum Plumbing Forum Discussion & Blog
    Last Post: 03-05-2008, 12:06 PM
