Results 1 to 5 of 5
Thread: Street 45/45 closet flange vs. spigot closet bend
    DIY Senior Member Noth Jersey's Avatar
    Jan 2009
    Hopatcong, NJ
    Default Street 45/45 closet flange vs. spigot closet bend
    I'm finishing off my basement as a dedicated home theater, and I want to avoid building a soffit around my toilet plumbing. My floor joists are 2x8, and I have about a 4-1/2' run to the main stack. I'll be replacing the copper elbow that presently juts well below the joists.
    What are the merits of using a spigot closet bend vs. a 45 closet flange with a street 45?
    http://www.terrylove.com/forums/showthread.php?t=17876
    On a side note, to make the degree symbol you can use either use Alt+0176 (on the number pad only) or you can insert the symbol using Microsoft character map.
    Default opening
    No advantage either way, at first. BUT, if you ever have a problem and have to redo it, the spigot closet bend will be faster and easier, especially if it is a 3"x4" spigot bend.
    Jan 2009
    Hopatcong, NJ
    Does any manufacturer in particular make a closet bend that provides more clearance than the rest?
    I'll be sloping down only about an inch over the four or five feet to the wall, but a 2x8 bay seems pretty shallow to me.
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    Same question for me! I may be coming up short on vertical clearance and I'm looking for the shallowest fitting possible...
    The shallowest possible is the 4x3 spigot closet bend with a 4" hub closet flange.
