Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Main valve buried in cement needs replacement, How would you break it out?
  1. #16
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    At least nothing except NOT take a half day to do it.
    You are a trained profesional. Bet I can install a receptacle faster than anyone here.
  2. #17
    Sound and Light Suppervisor for a School District tjbaudio's Avatar
    Dec 2005
    Wisconsin
    quote; I cannot think of one thing I would have done differently
    Yup, could have done it faster, or I could have taken longer. Since I was not on the clock I did it at my own pace with out rushing in any way. I figure if I were to hire this out I would expect it to take 1 to 2 hours and several hundred $$$. Had I not made a bad joint it would have been done in just under 3 hours. Total cost? a couple of parts out of the bin, some mapp gas and some time. Most of the extra time was spent cleaning old solder off of fittings I did not want to cut out or looking for a tool I did not have handy. I also wanted other diyers to know to plan some time for this kind of project. BTW that is the first bad joint I have made in the process of repluming my entire house, plus helping out a few friends with there pluming projects over the years. Yup, screwed that one up.
    tjbaudio
    I have a mild form of Dyslexia that affects my ability to spell. I do use spell checking to help but it does not always work. My form of Dyslexia does not affect my reading. Dyslexics of the world untie!
    www.incertclevername.com
  3. #18
    quote; Bet I can install a receptacle faster than anyone here.
    Don't let your mouth make a bet your hands can't cover.
  1. Two quotes - difference of more than double? (pricey one doesn't even break cement)
    By bucky in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-17-2011, 10:43 AM
  2. Main water valve replacement
    By darmstro in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-01-2011, 01:38 PM
  3. Material for replacement buried main water line from the curb?
    By greendog in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-18-2011, 11:41 AM
  4. Could a valve replacement cause other valves to break?
    By Koru04 in forum Irrigation / Sprinkler Forum
    Last Post: 06-26-2010, 11:55 AM
  5. main water line break
    By flabbb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-17-2007, 12:11 PM
