Results 1 to 15 of 18
Thread: Main valve buried in cement needs replacement, How would you break it out?
Hybrid View
    Sound and Light Suppervisor for a School District tjbaudio's Avatar
    Dec 2005
    Wisconsin
    Default Main valve buried in cement needs replacement, How would you break it out?
    Hello, I have an old house that has had many changes over the years. I am not sure when the pluming was changed from a well to city water main, could be the 70's could be the 40's. The original foundation is stone. At some point the basement was dug out (or possibly added) and the stone backed up with cement block and the space between the block and stone, a ft or 2, back filled with pea gravel. The original water valve was partly buried in the cement block. I have no idea what kind of pipe is in the wall, if there is open space or what not. The existing valve was sweated to 3/4" soft copper tubing on the inside. A few years ago I added a ball valve. The joint out of the original valve is now leaking and I need to dig it out and do a proper fix. Monday morning I will have the city shut off at the curb before I start to hammer at it. Given what we know, or don't know, how would you bust out the old valve? I want to minimize damage to the pipe and nearby sewer line. I have several tools at my disposal. A big hammer, 1/2" flat stone chissle, 1" star chissle, hammer drill, pneumatic chissle, large and small side grinders with masonary blades.
    With any luck I should end up with a copper pipe I can just use a compression fitting on. Do I need to cut it off or can I use a compression fitting over the tinned end? I expect I will have to back fill the hole with cement as well. Any speculation on what else I may find for materials hidden away?
    Thank you.
    tjbaudio
    I have a mild form of Dyslexia that affects my ability to spell. I do use spell checking to help but it does not always work. My form of Dyslexia does not affect my reading. Dyslexics of the world untie!
    www.incertclevername.com
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    Shut off the water, take a hammer drill with a chisel point and just start chipping it open. Make a decent size hole that you can work with, and see what you have.
    Unsolder the old valve from its copper tube, then solder on a coupling and short piece of copper between it and the ball valve. Although, I would probably solder the ball valve on to the old pipe, it there was enough room for the handle to turn.
    Dec 2005
    Wisconsin
    Quote Originally Posted by big2bird View Post
    Thank you. That's about what I had in mind. I have a 12" or 18" long bit for the drill. Start breaking up the 1/2 block above the valve. Once it is out I can work down to the valve and pipe.
    tjbaudio
    The solder joint is only about 3/4" inside the wall so all you have to do is "break out" around the valve. You do not have do a major demolition job on the wall, nor will you have to "patch" it afterwards.
    Dec 2005
    Wisconsin
    One concern I have is that the curb stop is not 100% at least I don't think it is. I was thinking compression fitting to the first valve so I dont have to worry about the little dribble messing up the joint. At the least I could go small on the chipping at first.
    tjbaudio
    There are tools and techniques that can handle a slow leak - JetSwet would work and one of those disks that swell, and eventually disolve might work long enough to allow you to solder. You couldn't use a freezing unit, as you'd need access to more of the line in the wall.
  1. Two quotes - difference of more than double? (pricey one doesn't even break cement)
    By bucky in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-17-2011, 10:43 AM
  2. Main water valve replacement
    By darmstro in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-01-2011, 01:38 PM
  3. Material for replacement buried main water line from the curb?
    By greendog in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-18-2011, 11:41 AM
  4. Could a valve replacement cause other valves to break?
    By Koru04 in forum Irrigation / Sprinkler Forum
    Last Post: 06-26-2010, 11:55 AM
  5. main water line break
    By flabbb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-17-2007, 12:11 PM
