Results 1 to 13 of 13
Thread: Need seriouse help with my diverter valve trim
Hybrid View
    DIY Member boardable's Avatar
    Sep 2012
    San Jose, Ca
    Default Need seriouse help with my diverter valve trim
    Ok so here is the deal. Got a delta diverter valve with trim. When I installed with the kerdi the only mixing valve seal available was the standard 4 inch. but the trim ring for the diverter valve is smaller. I need a larger trim to cover it preferably one that is 5.5 " Any ideas.
    Kerdi is waterproof as long as you get at least 2" overlap and properly embed it in the thinset. KerdiFix is a urethane sealant. The combination of the two should give you a good seal, just apply a patch (use KerdiBand for less buildup if you prefer). Also, keep in mind that most trim rings also have a gasket to keep water out. Only if you're dealing with a steam shower is it imperative to seal around the valve really tight.
    Sep 2012
    San Jose, Ca
    Jad, that is all done. I used the mixing valve seal which is a seal that you put on that basically insures any water that leaks in comes back out and never gets behind the wall. It is a essential part of the kerdi system. That is why the hole is so big. So to simplify it let's just say the hole is too big so I need a bigger etscutcheon. But diverter valves take a very flat one.
    What is the diverter model number? Saying you have a Delta diverter is like saying you have a Ford car, but not telling WHICH Ford it is.
    Sep 2012
    San Jose, Ca
    The model is the delta linden. But I looked at all the delta valve trims just to see if I could get a repair part and none will fit. I even paid a extra 40 bucks and ordered the vintage look trim to take up more room and still there is a little gap to be seen.
    When you say "vintage look" do you mean you got the #RP42414 "Victorian backplate"?
  1. Trim options for a Moen 3372 valve diverter
    By wgnorton in forum Shower & bathtub Forum & Blog
    Last Post: 06-18-2011, 08:44 AM
  2. Dornbracht MEM pressure balanced valve trim with integral diverter problem
    By ONLYM in forum Plumbing Forum Discussion & Blog
    Last Post: 01-08-2011, 01:23 PM
  3. Can anyone tell me what brand of trim is compatible with this diverter valve?
    By dig4fyre in forum Shower & bathtub Forum & Blog
    Last Post: 09-11-2010, 12:38 PM
  4. Can anyone tell me what brand of trim is compatible with this diverter valve?
    Last Post: 09-11-2010, 09:27 AM
  5. Shower Diverter on Valve Trim or Spout?
    By pmetiv in forum Shower & bathtub Forum & Blog
    Last Post: 10-17-2008, 03:19 PM
