Results 1 to 11 of 11
Thread: richmond rheem and whoever else - Model: RTG-74 PVN -- make and opinions...
Hybrid View
    DIY Junior Member haeffnkr's Avatar
    Apr 2007
    Missouri
    Default richmond rheem and whoever else - Model: RTG-74 PVN -- make and opinions...
    Hello,
    I have an opportunity to purchase a used Model: RTG-74 PVN
    It is pictured as a Richmond Unit, but as I found below this is made by someone and imported by several manf. it seems.
    Brand Models
    Paloma PTG-74PVN; PTG-74PVP; PTG-74PVN-1; PTG-74PVP-1; PTG-74PVNH; PTG-74PVPH; PTG-74PVNUH; PTG-74PVPUH and PH-28RIFSN; PH-28RIFSP; PH-28RIFSN-1; PH-28RIFSP-1; PH-28CIFSN; PH-28CIFSP; PH-28CIFSN-1; PH-28CIFSP-1
    Rheem RTG-74PVN; RTG-74PVP; RTG-74PVN-1; RTG-74PVP-1
    Ruud RUTG-74PVN; RUTG-74PVP; RUTG-74PVN-1; RUTG-74PVP-1
    Rheem-Ruud GT-199PV-N; GT-199PV-P; GT-199PV-N-1; GT-199PV-P-1
    Richmond RMTG-74PVN; RMTG-74PVP; RMTG-74PVN-1; RMTG-74PVP-1; RMTG-74PVNH; RMTG-74PVPH; RMTG-74PVNUH; RMTG-74PVPUH
    Supposedly this unit has only been in use for 6 months and the sellers are selling the house and the new owners are going all electric in the house.
    Any way... they are asking $300 and I have not been able to find much on these units.
    I see both positive and negative reviews.
    Who actually made these and are they decent units?
    I have a 10 year old Aquastar 240 fx ( bought out by Bosch) unit that is starting leak in the heat exchanger and need to get something else soon before mine dies completely.
    http://images.craigslist.org/3E23L13...0e81d01fb4.jpg
    thanks Kevin
    Plumber jimbo's Avatar
    Paloma Industries is the (japanese) parent company of Rheem/Ruud/Richmond. They make a good product.
    You are better off with a powerball ticket than buying a used WH of 'the list' or 'the bay'
    Yakima WA
    You also need to determine that you have a gas line sufficient to supply the heater. Unless the house was designed for a tankless heater, it likely isn't big enough.
    quote; You also need to determine that you have a gas line sufficient to supply the heater.
    In addition, the flue usually has to be stainless steel, not aluminum "B" vent, which can get expensive very quickly if it has to make turns or go through multiple floors to the roof.
    DIY Member Killer95Stang's Avatar
    Mar 2012
    Southern CA
    I went through a tankless retro-fit in my 1961 house about 7 months ago. It involved re-piping my main gas line from the meter to the unit, to supply the units 199K btu requirement. I bought the Rheem High Efficiency Condensing unit, which allowed me to use 3" PVC for the intake and exhaust vents. The difference in not needing the stainless vent pipe, paid for the upgrade for the high efficiency unit. Although the payback will probably be about 16-20 years since its only two of us, their is nothing like having unlimited hot water, no matter how many people take a shower. Plus, we went from $15-$20 gas bills in CA, to averaging around $8.00 per month for gas.
    Apr 2007
    Missouri
    I already have a 1 1/4 main going about 65-70 feet then a 3/4" 5 foot run going to my existing tankless water heater.
    My meter is upgraded - 2 times actually... I have a pool heater to with a 2 pound separate 1/2" line running to it.
    My current unit is 165K so going to 199K would be no issue.
    There is also a Noritz on the CL that was never installed and has never been warranty registered...it is 250K.
    My current unit uses some single wall pipe going through a collar, as recommended by Aquastar, out the wall... run is about 2-3 feet total.
    So piping this unit out is not a deal breaker.
    thanks for the input so far...trying to find the best unit for me before my leaking one dies completely.
    Kevin
    DIY Senior Member lifespeed's Avatar
    Apr 2007
    California
    Which model Noritz?
  1. Paloma PHH-32DV condensing Tankless water heater installation
    By saphman in forum Tankless Water Heater Forum
    Last Post: 01-19-2012, 05:19 PM
  2. Need Help with New Toto Models
    By SAS in forum Toilet Forum discussions
    Last Post: 09-15-2009, 06:03 PM
  3. Best Toto Eco models
    By pottymouth in forum Toilet Forum discussions
    Last Post: 10-01-2008, 02:41 PM
  4. Dishwasher Models
    By George in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-16-2006, 08:05 PM
  5. Brand new pump, brand new tank
    By Molly in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-05-2005, 06:18 PM
