Results 1 to 4 of 4
Thread: How big of a problem might it be when a sticker is left in an ABS pipe fitting?!?!?
    DIY Junior Member Brian Goldstein's Avatar
    Nov 2012
    Los Angeles
    Default How big of a problem might it be when a sticker is left in an ABS pipe fitting?!?!?
    My friend was a little lazy when putting together some ABS pipe fittings. He didn't take the item id sticker off a reducer before gluing it in place. I pointed out the potential problem that it could cause a weak weld at that point, and the weld probably isn't even complete at that place. He's not worried, but i always worry about the details. Does anyone have an idea of how big of an issue might this be? Could it prevent the piping system from passing code? Is that sticker going to break down over time and cause a leak? This particular fitting shown in the picture is a vent section, so it wouldn't cause a water leak, but possibly a very slow sewer gas leak? There was another connection of two inch pipe to three inch pipe that was a drain section... and now i'm having trouble sleeping. Should i cut this out and replace it??? Should I dig up the drain underground and check whether the sticker was left on that reducer, and replace it if it was?
    Should I be worrying?
    Sep 2009
    Seattle. WA
    Perhaps a very slight chance of miniscule leakage in the impossible event that that vent pipe ever got filled with "water".
    If your obsession won't let go, you could scrape off the visible part of the label, use cotton swabs soaked in mineral spirits
    to clean off the label glue, and then swab the area liberally with ABS cement.
    As for the underground pipe: what's the harm if a few extra drops of moisture get in the dirt?
    If this plumbing work is going to be looked at by an inspector, well, I just don't know. He/she might just look at it
    and wince, but maybe not. Some of those guys/gals are pretty mean.
    Aug 2009
    South*East
    Yes it can leak and any leak be it sewer gas or water isn't good. No matter were it is.
    John
    If this is the only thing you have to worry about, then you are a very lucky person. It will NOT leak, because there was enough "exposed" material at the bottom of the joint to make an adequate seal. Even if there were not, it is an "open" pipe so there is absolutely NOTHING to create the pressure which would cause a leak. Now, start worrying about Brazil depleting the rain forests or something important.
  1. Problem sweating second joint on a fitting
    By camner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-23-2009, 08:33 PM
  2. Soft close seat: Ugly sticker hard to remove, upgrade to a Washlet
    By intravenous in forum Toilet Forum discussions
    Last Post: 12-02-2008, 02:45 PM
  3. Questions - Carlyle vs Carolina? Water Supply? Sanagloss sticker?
    By idesign123 in forum Toilet Forum discussions
    Last Post: 11-16-2008, 09:32 PM
  4. Need Help With PVC Pipe Fitting
    By convexion in forum Irrigation / Sprinkler Forum
    Last Post: 09-23-2008, 12:17 PM
  5. problem with abs fitting
    By bimmer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-22-2007, 02:11 PM
