Results 1 to 5 of 5
Thread: What is this rusted fitting?
    DIY Junior Member PKO's Avatar
    Nov 2012
    Rowland Heights, CA
    Default What is this rusted fitting?
    Name:  overall view large.jpg
Size:  72.2 KBName:  rusted large.jpg
    I have a leak below the PRV which I'm planning to fix/replace. Since I'm there I'd also like to replace the valve with a ball valve. I have a couple of questions.
    1) What is this rusted fitting and do I need it?
    2) Are there any suggestions before I dive in?
    Thanks,
    Pat
    It looks to be a galvanized threaded plug.
    No purpose at all. Perhaps it was a hosebib at one point there.
    If it were ahead of the water meter, it would have been someone's attempt to "steal" water. If it is not in your way, just remove the steel plug and install a brass one.
    I vote for future sprinkler system connection (assuming there is meter at street).
    Given exposed exterior supply I guess warm weather climate where sprinkler systems are very popular so "tee" is part of normal install when house was built allowing easy addition of sprinkler system.
    Just looked up Rowland Heights, CA. May thru Sep has average high near 90 with less than 0.25" of rain per MONTH. I bet sprinkler systems are quite popular among the green thumb crowd...
    Nov 2012
    Rowland Heights, CA
    Quote Originally Posted by wraujr View Post
    Hmm. Never thought the builder would be that considerate. You're right. Almost everyone around here has sprinkler systems.
  1. What kind of union fitting is this? Ford Fitting
    By DavidTu in forum Plumbing Forum Discussion & Blog
    Last Post: 04-21-2011, 10:25 PM
  2. Help...Rusted fitting won't come off...Do I need a plumber?
    By housegal in forum Plumbing Forum Discussion & Blog
    Last Post: 05-20-2010, 08:14 AM
  3. How to replace a copper fitting close to another fitting
    By jfhardy in forum Plumbing Forum Discussion & Blog
    Last Post: 11-26-2008, 08:48 AM
  4. Rusted lav needs replacement
    By Terry in forum Plumbing Forum Discussion & Blog
    Last Post: 12-28-2007, 06:52 PM
  5. My Flange is rusted apart
    By hartless in forum Toilet Forum discussions
    Last Post: 02-18-2005, 07:51 AM
