Results 1 to 6 of 6
Thread: Why Can't A Double Sanitary Tee Be Used Here
    Oct 2011
    Default Why Can't A Double Sanitary Tee Be Used Here
    Why can't a double sanitary tee(DST) be used here instead of the double fixture tee(double fixture fitting)? Does it have to do with in case the line needs to be snaked? The snake most likely would have a tough time going down once it reached the DST?
    What is a situation where a double sanitary tee can be used?
    A double sanitary tee can be used for a vent fitting.
    If you snake a double santee, the snake goes right across and toward the other p-trap.
    I knew a guy that pushed his snake right through an aging brass p-trap in the next condo unit.
    Oct 2011
    Makes sense. Thanks.
    That guy wouldn't of happen to be Terry would it??
    No......I heard that one at a high school reunion. A guy that became a dentist was doing handyman work while in college. He said he was pushing real hard on the snake and was quite happy he was able to push it through until he found out what he had done.
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    That's funny as h*** right there.
    A sanitary cross creates "crossover" of waste is "almost" impossible to snake through it. A double "combo" creates "3/4 S" traps, so the double fixture fitting is the only proper one. A "'double sanitary tee" is not necessarily a "sanitary cross". There are double sanitary tees with the two inlets one above the other and others with them a 90 degree apart.
    My first boss told me about a job where he was using a flat steel tape through a closet bend. He hit an obstruction right after pushing it in, so he "pounded" it a couple of times and it continued to go in. It was a short time after that the tenant next door was pounding on the door because he had "something" coming out of his bathroom and snaking across the dining room floor. One time, I was snaking a supermarket drain from the back of the building. I had about 140' of snake in the drain, which should have put me at the front of the building, so I went outside to open the front 2 way cleanout to see if I was there yet. But when I got there, my snake had turned up from the combo, pushed the cleanout cover off and was going across the sidewalk. Some "dimestore cowboy" had "wrestled" it the ground and hogtied it around a post.
  1. Repairing PVC double sanitary tee?
    By jamesfjamesf in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-21-2012, 04:13 PM
  2. Double fixture tee or double sanitary tee?
    By nc8861 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-03-2011, 11:33 AM
  3. double sanitary tee in Canada
    By segal46 in forum Canadian Plumbing Code Questions
    Last Post: 06-26-2010, 08:37 PM
  4. double sanitary tee in Canada
    By segal46 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  5. Double Sanitary Tee or Double Wye?
    By MG in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-26-2007, 11:45 AM
