Results 1 to 15 of 16
Thread: Connecting 3/8" PEX to a standard water shutoff
Threaded View
  1. #8
    DIY Junior Member 180pilot's Avatar
    Jan 2013
    Bakersfield, CA
    I believe the Pex being so stiff, and wanting to stay curled was putting so much side load on the compression nut, it just felt as if it was getting tight against the sealing ring. At second try, I held the tubing so it was straight into the valve with no side load while tightening nut. All is well so far no leaks. But I'll confirm there were no inserts in the parts kit, nor did the instructions show any for the optional shortening of the lines. 9 days and Delta support still has no answer to my question. If I had it to do again, the unsightly under sink clutter looping of the very long amount of tubing would still be a consideration for me. I would think Delta had done some research on the two different methods before offering the option. I went to local hardware with piece of cut off Pex and tried to force a brass insert into it, it could not be done with just my hand and arm pressure against a hard surface as with the soft poly tubing. Are there special diameters of insert for 3/8 Pex??? If so my hardware store did not know of them.
  1. Old Toilet "Standard" same as American Standard? Parts?
    By molo in forum Toilet Forum discussions
    Last Post: 10-29-2012, 08:12 PM
  2. replacing shower body--what does "supply building with main shutoff valve" mean?
    By dayexday in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-03-2012, 10:29 AM
  3. Connecting a 1/4" tube to water supply???
    By Montalvo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-17-2012, 06:08 AM
  4. Connecting water tank to 1" trunk
    By DavidTu in forum Water Heater Forum, Tanks
    Last Post: 02-07-2012, 08:35 PM
  5. Connecting a 1-1/4" fleck 7000 bypass valve to water supply
    By geod in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-01-2011, 10:34 AM
