Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Connecting 3/8" PEX to a standard water shutoff
    DIY Member ddmoit's Avatar
    Jan 2007
    SE Tennessee
    Default Connecting 3/8" PEX to a standard water shutoff
    Hi folks. I just moved to Tennessee from Michigan. I'm installing an under sink water filter. It's a unit that uses 3/8" PEX on both ends. The connection piece that they gave me to connect to my cold supply is useless for my circumstance. What's the best way to connect PEX to a standard cold water shutoff valve without using special tools? Can I use an old fashioned nylon compression fitting like the ones commonly used for ice maker connections?
    Thanks for your attention.
    Dan in SE Tennessee
    Plumber jimbo's Avatar
    yes........
    Jan 2007
    SE Tennessee
    Do I sense an impending qualifying statement, or am I reading too much into the trailing periods?
    Dan in SE Tennessee
    What is wrong with the connection they gave you? There is no such thing as a "standard cold water shutoff valve", because there are many types of cold water shut off valves.
    Jan 2007
    SE Tennessee
Size:  89.0 KB This is what was provided.
Size:  57.6 KB This is what I have. It fit my new Delta faucet perfectly. I can add a splitter to the top of the shutoff valve to connect my faucet and the water filter.
    Dan in SE Tennessee
    The adapter looks to be 1/2" pipe threads x 3/8" OD.
    Your shutoff is 3/8" comp or also considered 3/8" OD
    You may want to pick up a double shutoff for the wall fitting
    or a 3/8 comp x 3/8 comp x 3/8 comp tee for the top of your current shutoff.
    Jan 2007
    SE Tennessee
    The triple 3/8 tee is what I ended up doing. I'm just concerned about the PEX compression fitting holding. I used a nylon ring, properly installed. I suppose it's no worse than the line going to the new Delta faucet. A leak would be bad in a hurry though.
    Dan in SE Tennessee
    They make inside sleeves for the tubing too.
    Jan 2007
    SE Tennessee
    Yeah, I actually have one. In all the excitement of putting it together, I failed to use it.
    Dan in SE Tennessee
    The inside sleeve provides a hard, smooth, round surface to support and mold the pex so the compression fitting will hold and seal properly. It is included for a reason, you should use it! The connection will be much more robust.
    The connection Tee they gave you was to go between a "flexible hose" supply line and the 1/2" MIP threads on most conventional faucets. Delta, because of their DST versions no longer uses the MIP connection which is what caused your difficulty. The "Add-a-Tee" adapter you used is what I would have used also.
    Jan 2007
    SE Tennessee
    Thanks for all the input. Jim, I'll add the sleeve. I have a dishwasher to install in a few days, so I'll be under there again.
    Dan in SE Tennessee
    DIY Junior Member 180pilot's Avatar
    Jan 2013
    Bakersfield, CA
    Default Delta supplys no insert for DST Pex faucet installation?
    Installed new Delta DST kitchen faucet, and because supply lines were so long, I cut off the manufactured ends and opted to use the nylon compression rings supplied with the kit to 3/8" angle stop valve No insert is provided. Instructions say to turn compression nut 2 full turns after hand tightning, that seemed way too tight at first try, but hot water side let go within 15 min. flooding kitchen. I then retightened to much tighter and then removed tubing to see that nylon compression ring was crimping tubing. And did a pull test. I installed ring in correct manner and deburred end after cutting with standard tubing cutter. It's holding now, but I can't find any recommendation to use an insert inside Pex tubing except on your site here?????? It seems standard practice with softer polybutylene?????? A call to Delta, just produced a woman trying to blame me for not cutting tubing correctly!! I'm an aviation mech. and have been making tubing connections for 40 yrs. Tubing was cut square and deburred. Connection makes me nervious, I always turn off my outside incoming water valve when I leave home, because all my plumbing is 20 yrs old....
    Quote Originally Posted by ddmoit View Post
    No "oh by the way" will follow! The forum requires minimum 10 characters in a reply,...hence the dots.
    quote; No insert is provided. Instructions say to turn compression nut 2 full turns after hand tightning, that seemed way too tight at first try, but hot water side let go within 15 min. flooding kitchen
    You discovered the reason why I NEVER cut the manufacturer's supply lines. I just loop them to use the whole thing.
  1. Old Toilet "Standard" same as American Standard? Parts?
    By molo in forum Toilet Forum discussions
    Last Post: 10-29-2012, 08:12 PM
  2. replacing shower body--what does "supply building with main shutoff valve" mean?
    By dayexday in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-03-2012, 10:29 AM
  3. Connecting a 1/4" tube to water supply???
    By Montalvo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-17-2012, 06:08 AM
  4. Connecting water tank to 1" trunk
    By DavidTu in forum Water Heater Forum, Tanks
    Last Post: 02-07-2012, 08:35 PM
  5. Connecting a 1-1/4" fleck 7000 bypass valve to water supply
    By geod in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-01-2011, 10:34 AM
