Page 1 of 4 1234 LastLast
Results 1 to 15 of 48
Thread: Water Softener Settings & Salt/Brine Grid Question.
    DIY Junior Member John5's Avatar
    Nov 2012
    New Brunswick, Canada
    Default Water Softener Settings & Salt/Brine Grid Question.
    Hi,
    I got tired of washing dishes by hand or hiding them in the oven so I finally broke down and installed a softener...
    I have "temporary" hard water, total hardness 224mg/l (13.44 grains) iron is negligible (0.039mg/l).
    Using Gary Slusser's Softener Sizing Chart and Cubic Foot and Capacity Calculator and based on a 75 gal/day usage I obtained a suggested softener capacity of 8157.6 grains with .5 cu/ft media and a 10 day regen. I did not consider .5 cu/ft adequate for my SFR or future household needs, I live alone at the present time but to get suitable Service Flow Rate and to allow for another person or family later on I opted for a 1 cu/ft softener. It is my understanding that the minimum practical or recommended salt dosage is 3lbs cu/ft, again playing about with Gary's Cubic Foot and Capacity Calculator I came to the conclusion that 12,800 grains is sort of the minimum practical capacity of 1 cubic foot of media with a 3lbs salt dose.
    My softener is:
    - Fleck 7000 SXT with 1 cu/ft resin
    - .12 gpm (.37lb/min) BLFC
    and my settings are:
    VT: dF2b
    CT: Fd
    C: 13,000
    H: 13 (my hardness is 13.44 should I round up to 14... or is 13 good enough?)
    RS: SF
    SF: 10
    DO: 8
    RT: 3:30
    Cycle times are (minutes):
    B1: 10
    BD: 60
    B2: 0
    RR: 10
    BF: 9
    After a regen the softener indicates that I have 948 gallons available.
    My questions:
    1- Do my above calculations, assumptions and settings look correct? Any comments?
    2- My Fleck manual says that the second backwash (B2) is not normally used and to set it to 0 unless instructed otherwise by a qualified technician. Yet, in some other documentation on the internet it is suggested that a second backwash of 5 minutes or so be set to avoid the risk of resin channelization. Should I set a second backwash? Comments?
    3- I have a salt/brine grid installed. the type with 4 coffee cup sized legs with about 1/4" holes in the bottom of the cups. After the brine draw there is about 2-1/2" of brine remaining in the bottom of the tank, that is at the valve check mark. (The softener empties the tank at about 1/2 to 3/4 ways into the BD cycle and then sucks air for the remainder of the cycle). The 9 minute brine fill adds about 2 inches of water to my 12" x 12" tank for a total of about 4.5" of water after the fill, the grid level is at 5 inches, so, except for the salt in the cups, the salt is above the water. Do those 4 coffee cup legs with the 1/4" holes at the bottom really work and allow for the proper creation of fully saturated brine? Will those 1/4" holes in the bottom of the legs eventually plug up?
    Thanks in advance;
    John
    Nov 2010
    Maine
    [QUOTE=John5;362626]Hi,
    My questions:
    Look fine to me
    I wouldn't bother with the 2nd backwash. Channeling though not uncommon isn't all that common either.
    Thanks in advance;
    Everything in the brine tank is as it should be and you should be fine although it's not a bad idea to clean your brine tank once a year. Best of luck with your new system. You will be more than happy with the Fleck7000
    Jan 2012
    California
    The brine grid does not hinder the brine solution nor does it help. Water will disolve salt and max out at approximately 3 pounds of salt per gallon, this varies slightly depending on water temperature, but it is not critical to adjust for this unless you are planning on using potassium chloride.
    The brine draw cycle should not "suck air", if it does, you have a bad aircheck. Probably just a misunderstanding, but in the bottom of the brine tank is a floating aircheck, when the water runs low, the air check will seat causing the system to suck nothing for the remiander of the BD cycle. It will simply "slow rinse".
    As to the second backwash, if you are using the 3 pounds per cu. ft. brining, I would recommend the second backwash. Salt settings above 6 pounds, it is not needed. The second backwash is not used to prevent channelling, the first backwash does that. It is used to mix the highly regenerated top portion of the resin with the less regenerated bottom portion of the resin. This is an old trick used for ultra low salting systems to give higher quality soft water. It is only 10 gallons, I would recommend it. If you dont, the system will still work very well. The difference is typically less than a few ppm difference. If you want to save water, then split the backwashes, 5 minute first backwash, 5 minute second backwash.
    Always round up the hardness, and it is normal to add a couple of grains for a buffer, to accomoadate for regular variations in the water supply.
    Sounds like you got yourself a great setup, congrats and enjoy!
    Nov 2012
    Thank-you, Tom.
    Nov 2012
    Thank you, Dittohead. I will bump up the hardness settings and set a second 5 minute backwash. The 7000SXT valve is noisy, I'm not sure if it is actually sucking air but I'll double check to make sure that it isn't.
    John
    DIY Senior Member lifespeed's Avatar
    Apr 2007
    California
    I would change DO to 21 days at least. An 8 day override will have you regenerating with capacity still left.
    No more than the reserve if he has it programmed correctly.
    And he needs a reserve as all regular softeners do, or, if a twin tank, an amount of capacity to be able to use softened water to regenerate the other tank with.
    Jan 2012
    California
    Thanks LifeSpeed for the catch on the DO. As long as water is being used intermittently, the DO at 21 or 30 will be fine. The reserve is programmed in the SF, 10% of the systems capacity is set as the reserve.
    The SF setting specifies what percentage of the system capacity will be a reserve. Since this value is a percentage, any change to the system capacity or feedwater hardness that changes the units calculated capacity will result in a corresponding change to the reserve volume.
    Nov 2012
    Quote Originally Posted by lifespeed View Post
    That is contrary to what is being said almost everywhere on the internet and in almost all softener documentation, most say to not allow more than 10 to 14 days between regens for better resin life and performance.
    Jan 2012
    California
    Quote Originally Posted by John5 View Post
    Please link to the manufacturer of resin that states the resin should be regenerated every 10-14 day. I work directly with every major resin manufacturer they all agree that for residential applications, run times of 30 days is not an issue unless there is considerable fouling potential (Iron, Manganese primarily). The DO is important primarily for systems that do not receive any water flow for extended periods of time. (vacation homes) Non electronic systems, (5600, 9100, 9000, Kinetico's, etc) all can go for months without regenerating if the water flow is low, and these systems do just fine. Even my own house only regenerates monthly for the past 10+ years, no problems yet. Every major portable exchange tank company tries to size the equipment for monthly routing to save on fuel and labor costs. We had tens of thousands of tanks in the field regenerating no more than monthly, with no issues for decades.
    Honestly, there is no need to be concerned with regeneration frequencies, unless they go beyond 30 days, then you might consider a different design.
    A good example of where this becomes a common issue is a large house, a few people, and a large main line with low hardness, 5 grains. The SFR and pipe size by code may require a 2.5 or 3 cu. ft. system. The water usage may only be 120 gallons per day, and the system has a capacity of 50,000 grains.
    120 gallons x 5 grains = 600 grains per day / system capacity of 50,000 = 83 days between regenerations. This is not an uncommon issue to run into. You could regenerate at minimum salting, dropping the capacity to 35000 grains, but this still puts you at 58 days.
    In this situaton, the 30 day over-ride will come into play. If the homeowner left it with no DO, the system would still be just fine.
    Nov 2012
    I'm not an expert, that is why I came here asking for advice, and I much appreciate you guys taking time to freely share your knowledge! There is a lot of conflicting (or outright wrong) information out there so the less knowledgeable ones (like me) can often be led down the wrong path. Many seemingly reputable sites say something along these lines:
    "For the majority of homes, our 30,000 grain unit (1 cubic foot of resin) is more than enough capacity. Ideally, a water softener should be sized so that it does not regenerate more often than 5-7 days, nor goes longer than 14 days before regenerating.(this can cause compacting of resin, and fouling with sediment or iron)." http://www.freedrinkingwater.com/faq...ofteners.htm#3
    Newbies like me see this repeated in many places so we are led to believe that it is best to regenerate at least every 14 days! Thanks for clearing this up, as far as I'm concerned if it doesn't harm anything then fewer regens is better, less salt used and less water wasted!
    Jan 2012
    California
    Correct, and the website you referenced ... I know them very well. The information is, umm... just read the information below from their website for their whole house carbon and TAC system.
    Unlimited ultra-pure, quality filtered drinking water – superior to bottled water
    Best tasting water for cooking and making delicious coffee, tea and ice
    Safe and healthy drinking water – up to 99% contaminant FREE
    Chlorine, chloramine & odor free water at every faucet & outlet in your home
    Chemical removal for healthier skin, hair and lungs after every bath or shower
    Reduced hard water spots & issues for easier household cleaning
    Scale reduction in pipes and all water appliances for improved performance, efficiency and longevity.
    Ultrapure??? Better than bottled??? With a carbon filter? 99% contaminant free??? Amazing! Many online retailers are more into marketing than anything else.
    You came to the right place for getting advice from people who are actually trained, licensed, and qualified to do so. Well, at least several of us here are.
    Althuogh I haven't looled it up lately, most resin manufactures say weekly regeneration for residential use of their resins. Your comparing exchange tank softening with a softener is not good because the exchange company didn't expect or get 15-20 years out of their resin as homeowners and small business people do.
    Also, you talk as if everyone reading your suggestions of 30 days and more between regenerations is on city water in California. They aren't and many DIYers have their own wells.
    Rather than you asking for us that say weekly or so to prove it, you should prove your claim that the resin manufacturers say 30 days or longer is fine.
    DIY Member ByteMe's Avatar
    Nov 2012
    Midland Texas
    OK folks. When I get him I have some manufacturer documentation that I believe says maximum of a 14 day regen. Very valid question, even ohiopurewater recommends 14 days.
    Will post when I get back home.
    Jan 2012
    California
    I am looking for documentation from the resin manufacturers. Purolite, Sybron, etc, Ohio Pure Water is a great group, but it is also nothing more than an internet company that has other companies drop ship product for them.
    If the documentation exists, great, but regardless, GE, Culligan, Rayne, Puronics, Seimens, and virtually all other companies that do portable exchange, which is nothing more than regenerating the resin off site, all try to run 30 day routes. That being said, there are also many protocols for regeneration plants, including water reuse, brine reclamation, etc, so it is not a true apple to apples comparison.
    My real question is, assuming a decent iron free water supply, what is going to happen if the resin does not regenerate every 14 days or more? And using my earlier example, what is the proper way around the massive salt waste that would occur if you forced a system to regenerate every 14 days if it only needs to regenerate every 30?
    With over 25 years of commercial, industrial, and residential experience, dealing with water and systems from all over the world, I will give you the simple answer. Nothing. It is fine to regenerate less frequently than every 14 days. The original 14 day idea is an old idea, written many years ago that has been cut and pasted for decades into companies literature. I have some great old literature that goes over the proper method of installing a softener, basically mandating that toilets must be bypassed. That old idea was finally abandoned a little over 20 years ago, although it still pops up from time to time. Most internet websites simply copy other websites literature, change a few words and voila, they are a "knowledgable" water treatment company. Sort of the same way some people try to take credit for the sodium in water to white bread analogy, or a can of baked beans. I heard those my first day of training, and to this day, people use those examples like it were their own.
    I have searched for a long tim e for the resin manufacturers to make any recommendations on regeneration frequency. It does exist on certain other medias, KDF, Pyrolox, Filox, Birm, etc, but resin, and most other medias do not. They have pages of information on regeneration capacities, flow rates, pressure curves, temperature ratings, pH ranges, freeboards, expansion rates, regenerant capacities based on regenerant, etc.
    All that being said, I think what is missing in this conversation is some guidelines. If you have water with turbidity issues, regenration frequency will be more important. Iron in the water... salt quantity and regeneration frequency are important, no water flow at all, (vacation home), regenerations should be done to prevent the stagnent water issues. For my vacation home, I have it set to regenerate every 14 days, but I change the salt setting to almost nothing unless it is occupied. A good clean water supply, why would frequent regeneration be necessary? What would happen if you went past 14 days?
    This idea is similar to the flow controls on RO debate. The old idea of a 4 or 5 to 1 ratio is still practiced, even though membranes now cost 1/5 of what they used too. Is the extra water waste worth trying to eek out another 6 months from a membrane? Your membrane will last 4 years instead of 4-1/2. If you have a softener, is it really necessary to have that bad of a ratio. Sorry, going off into a different area but I think the ideas from this industry that are still hanging in there from 25 years ago need to be addressed.
    25 years ago, meters were a "neat but expensive" item, and were rarely used, and the salt settings were 10-15 pounds per cu. ft. Now we are pushing 3-8 pounds of salt per cu. ft., and very few companies would even consider not using a meter, and in many states, it is not even legal to install a residential timeclock softener. Reputable distributors wont even sell single tank large commercial systems if they know that is improperly designed and highly wasteful in order to save a few dollars up front.
    The most recent article from Purolite written over a decade ago I have read that discussed resin regeneration frequency went both ways on the idea. Frequent regeneration leads to shorter resin life due to osmotic shock, lowering salt amounts and not allowing the resin to become completely depleted could protect the resin from the damaging affects of this problem, later in the same article it recommends increasing the regeneration frequency if fouling is a problem, iron, sediment etc.
    The article never did set what the frequency should be.
    Sounds reasonable to me
  1. Dumb water softener question, why does increasing the salt level lenthten regen time
    By jasper7821 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-08-2012, 10:08 AM
  2. Recommended best settings for 6700xtr 48,000 grain water softener
    By Lost Texan in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-05-2011, 08:30 PM
  3. Water Softener settings
    By OhioTurner in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-31-2011, 02:46 PM
  4. salt forming around outside of brine tank
    By chris fox in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-27-2010, 08:19 PM
  5. water softener brine pump
    By maddog62 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-20-2009, 06:33 PM
