Results 1 to 7 of 7
Thread: Pump Losing Prime Quickly
    DIY Junior Member xenon's Avatar
    Nov 2012
    Florida
    Default Pump Losing Prime Quickly
    I have a 120' well used for irrigation here in south Florida. Pipe is galvanized 2 & 1/2". Pump is a 1 & 1/2 hp Goulds centrifugal on a concrete slab next to the well pipe.
    After the pump was left unused for 5 months during the rainy season, it is losing prime within minutes after shut off.
    First I replaced the horizontal mounted check valve between well and pump. No change.
    Then I brought pump in and had it rebuilt, as it was probably 12 years old anyway. No change.
    I can get it to prime by attaching a hose to the bib on top of the pump, and running water in while the pump is operating. After 10 or 15 minutes the pump will prime. Once primed the pressure is excellent.
    There is no lack of water as the water table is now about 4' below ground surface.
    Any diagnosis?
    Thanks.
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    A good footvalve is the best way to keep from losing prime. You probably have one that is leaking back.
    Nov 2012
    Florida
    Quote Originally Posted by valveman View Post
    Thanks for the response. I took the plug off the top of the well pipe. Turns out there is no drop pipe; just the well casing. Water level is right at six feet down. Took a hose and ran water into the pipe to see if I could fill it. Pulled the hose after about five minutes and the level did not rise much but there was a lot of bubbling. Large bubbles.
    Dug the pipe down to about five feet. Pipe was clean to about four feet down and then had what looked like surface rust. Water started to show at base of the hole. Could be the ground water or could be from a hole in the pipe.
    What to do now?
    Well Drilling/Service justwater's Avatar
    May 2010
    NE FL, SE GA
    toss the above ground check valve and install 30' of 1-1/4" pvc drop pipe into the well with a foot valve on the bottom, then plumb that into the pump.
    ** fyi, i say 1-1/4" to get max volume but be careful because some fittings are tight inside a 2" ID well. i sometimes turn them down a little on a grinder before installing... you'll need to pull it all out again one day.
    Nov 2012
    Florida
    Quote Originally Posted by justwater View Post
    Thanks, that is a big help and explains about the 1 & 1/4".
    What fittings would I need to plumb the drop pipe to the pump?
    May 2010
    NE FL, SE GA
    they make a double tap fitting that screws into a 2" coupling and is tapped 1-1/4" on both sides.
    OR... use a simple 2" pvc threaded cap, drill a hole with a paddle bit that is just large enough that the drop pipe barely slips through.. slip pipe through and glue elbow/coupling onto pipe and let the drop pipe rest on the fitting. this is easier/cheaper and works quite well. you can seal it up with some silicone or something but if you make it a tight fit and being as its irrigation anyway.. its not necessary.
    Nov 2012
    Florida
    Excellent solution and right price, too.
    Thanks for your help. Much appreciated.
  1. Jet Pump losing prime whgile running
    By pktaske in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-14-2011, 10:19 AM
  2. shallow well pump losing prime sporadically
    By abeljda in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-29-2010, 07:00 PM
  3. pump losing its prime
    By joefla in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-02-2006, 01:39 PM
  4. shallow pump losing prime
    By smoothbore2004 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-24-2006, 06:53 AM
  5. well pump losing prime
    By cajunsally in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-04-2006, 10:16 AM
