Results 1 to 5 of 5
Thread: Sure could use some help on pump & tank.
    DIY Junior Member dENNIS MEYER's Avatar
    Oct 2012
    TEXAS
    Default Sure could use some help on pump & tank.
    Had well dug it's 130' deep. Trying to figure out what tank & pump system to use. Should I use the old style system with tank that you set the pressue on, or should I use the constant pump & tank system?
    The well will be used to water lawns & flower beds for two houses. One house is 275' from the well. One of the houses would like to set up a constant drip system for his flower beds. Does this mean that the pump on a constant pressure system will run all the time? I'm trying to find what is the best system for our use & also which one would have the least pump problem.
    Thanks for your help
    Moderator valveman's Avatar
    Mar 2006
    Take a look at this link to see how a constant pressure system and a old style pressure tank will work side by side. http://www.cyclestopvalves.com/simple/home.php
    Constant pressure can be done using a regular pump and a constant pressure valve, or a constant pressure pump that uses a computer to vary the RPM of the pump. The regular pump and constant pressure valve is inexpensive and will last a long time. The variable speed pump is more expensive and is not known for lasting very long.
    Oct 2012
    TEXAS
    valveman thanks for the reply. Let me ask you one question. If you was seting up my pump & tank how would you set it up?
    Jan 2008
    Virginia Beach, VA
    As valveman says "I would install a Pside-kick"!
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
  1. Well Pump Above Tank?
    By Billy_G in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-11-2012, 07:23 PM
  2. Pump to tank distance ?
    By 42skidoo in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-29-2009, 07:17 PM
  3. tank and pump; how to stop pump
    By mak123 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-29-2009, 04:42 PM
  4. tank and pump
    Last Post: 07-19-2009, 07:13 AM
  5. GPM from pump, or is it from tank?
    By rick.a in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-16-2007, 09:08 AM
