Results 1 to 7 of 7
Thread: old main shutoff valve
    DIY Junior Member tjetson's Avatar
    Oct 2009
    winnipeg
    Default old main shutoff valve
    Hi,
    Wondering if anyone can tell me anything about this valve and how it works
    The city cannot find the outdoor main shut off valve to the house so I dont want to possibly break this valve or disturb it and run into a situation where I cannot shut the water down without freezing the pipe.
    the knob at the top is very stiff and cannot be turned without great force. is it just an old gate valve?
    thanks!
    Aug 2009
    South*East
    That is a gate valve. Even if you did get it to close, there is a good chance that when you try to reopen it the stem can separate from the gate not allow it to.
    John
    Plumber jimbo's Avatar
    Yes, a gate valve with 90% of the handle missing. If you close it, there is also a 90% chance the stem will break, in which case you will never be able to OPEN the valve again. Are you seeing a new valve in your future?????!!!!!!!!!!!!
    The gate could also break off when you try to close it. One thing that IS certain is that with a buried galvanized supply line running through a concrete footing, the city WILL have to find that outside shutoff "someday" and maybe soon.
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    Probably on borrowed time ... If you are responsible for that line, see if your area has anyone supplying a waterline warrany. Then, just pray for it to break and they'll find the shutoff (or install a new one).
    Yakima WA
    Surely there is a shut off valve as part of the water meter! The comment about the city having to find a way to shut the water off sooner or later is very true. You have galvanized steel pipes, and this type of pipe has a limited lifespan. At the very least, you should replace the valve with a 1/4 turn ball valve. That won't extend the life of the galvanized pipe, but it will give you the means to turn the water off when necessary.
    The picture may show the water meter just above the valve outside the picture. If so, then it would depend on the utility's protocol whether everything ahead of the meter was their responsibility, or everything on the customer's propery, past the propery line, belongs to the homeowner. The city's shut off would be outside the property line. With a metal water line, its path would be easy to trace and then the city valve should be easy to pinpoint once you know where the pipe is and also the property line.
  1. replacing shower body--what does "supply building with main shutoff valve" mean?
    By dayexday in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-03-2012, 10:29 AM
  2. Main Shutoff Valve, Good Choice?
    By inertiacoupling in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-29-2012, 03:39 AM
  3. Why is sink shutoff valve still leaking after main water valve turned off?
    By kimana517 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-18-2008, 06:28 PM
  4. Leaking main shutoff valve on a well
    By ejhdmbfan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-11-2007, 08:09 AM
  5. Trying to put in a new main shutoff
    By jadnashua in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-26-2006, 08:42 AM
