Results 1 to 9 of 9
Thread: DWV Diagram
    DIY Junior Member luthar28's Avatar
    Nov 2012
    Ontario
    Default DWV Diagram
    Of course, the wife asked if she could move the toilet 'over there'. Me, being dumb, said 'yeah, no problem'.
    Problem. I'm having a heck of a time with venting. The basement is open and unfinished. Single story. These are some of the details:
    Distance from vent stack:
    - toilet: 7 feet (3")
    - tub: 10.5 feet (1.5")
    - sink: 2 feet (1.5")
    So I'm going to need to vent the toilet and tub, correct? This is what I've put together...don't know if it's the most economical or not (doesn't seem like it). Suggestions or comments welcome -- I could be completely wrong on this.
    (Note, the 3' on the toilet is supposed to be 3" - the pipe is 7' long).
    Name:  Doc - Nov 26, 2012 7-50 PM.jpg
    Jan 2008
    The 2-D drawing does not help us much. If it helps, the tub can drain to the the 3" line off the WC, as long as the connection is made after the vent.
    The pipe on the right..........is that existing?
    Is there anything coming down from above?
    Or anything down below?
    Nov 2012
    Ontario
    The pipe on the right is existing....everything else is simply planned.
    Nothing above or below.
    Then I would use the toilet vent to wet vent the tub.
    Nov 2012
    Ontario
    Thanks. Great diagram. So you're referring to the bottom portion, correct?
    Yes. This gives the basic concept.
    A tub waste is 2" with a 1.5" trap arm and 1.5" vent.
    A lav can use a 1.25" trap and waste, but most small DWV pipe is 1.5"
    Back before the 60's, you would see 1-1/4" in copper DWV and galvanized.
    Your "concept" as drawn is correct. Now all you have to do is install it correctly, which is not always a given. I hope that 10' tub drain is NOT all 1 1/2" pipe. We do not know enough about the room's layout to tell you if it is the best, or even most economical, method.
    Nov 2012
    Ontario
    Should I be using 2" in that 10 foot tub drain stretch?
  1. Help with wiring diagram
    By eric3872 in forum Electrical Forum discussion & Blog
    Last Post: 02-25-2012, 07:20 PM
  2. Help on DWV Diagram
    By Drewski123 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-25-2011, 06:09 PM
  3. Please give a look at this diagram. THX!
    By Geoff Clogan in forum Remodel Forum & Blog
    Last Post: 12-14-2010, 09:56 AM
  4. Plumbing Diagram Help
    By bdaub in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-01-2010, 08:36 AM
  5. Please comment on my DWV diagram
    By mjsmith0 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-17-2009, 02:00 PM
