Thread: Pressure Reducing Valve concern
    DIY Junior Member DRG32's Avatar
    Nov 2012
    Texas
    Default Pressure Reducing Valve concern
    I recently had a pressure reducing valve installed to fix our 105 psi static pressure. We also had an expansion tank installed, and it is the appropriate size for our two hot water heaters. I adjusted the PRV to about 60 psi, and I have noticed the pressure will climb to about 65 psi after someone uses the shower, bath, and some other times throughout the day. The pressure immediately drops back to the desired setting of about 60 psi when a faucet is briefly used, and the pressure tends to hang right around 60 psi for the most part. The instructions state that this is natural and that it may happen when the water heater runs. It also states that a pressure relief valve or expansion tank must be installed, but they will not prevent a pressure rise, but should limit it to a safe level. I understand the need for the expansion tank with the now closed system, but is this slight increase normal? Will this harm the expansion tank since the bladder is set at 60 psi? I really want this to be a trouble and worry free system. Any advice is greatly appreciated.
    I think you're fine. You didn't mention if you had set the pressure in the expansion tank to 60 psi to match the PRV, but your pressure is certainly well within safe range.
    The expansion tank will selfadjust to the prevailing pressure. You cannot "eliminate" thermal expansion, but the expansion tank controls it, which is why there will ALWAYS be a pressure increase when the water heater operates, but not as great as if there were no expansion tank. The slight build up when you turn off a faucet could be "surge" caused by the water's inertia when the flow suddenly stops.
    Nov 2012
    Texas
    Thank you very much. I appreciate the help.
  1. Could my new pressure balance valve be reducing my water pressure?
    By JenJen in forum Shower & bathtub Forum & Blog
    Last Post: 02-22-2011, 06:57 PM
  2. Installing New Pressure Reducing Valve
    By gazaman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-17-2010, 05:13 PM
  3. pressure reducing valve/relief
    By hidden 1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-15-2009, 04:19 AM
  4. pressure reducing valve
    By duffers in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2007, 05:45 PM
  5. Leaking pressure reducing valve
    By jwray in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-08-2005, 11:06 AM
