Results 1 to 7 of 7
Thread: running wire in anticipation of future update
    DIY Junior Member rioguia's Avatar
    Jan 2007
    Maryland
    Default running wire in anticipation of future update
    I plan to update the wiring in the top floor of my 1940's era house in the future. I have the walls open in the floor below and can easily run the wire for that purpose. 1. Can I just secure the wire to a floor joist near the main panel without installing it inside the main panel?
    2. If yes to question number one, do I have to terminate the other end of the wire in a switch or juction box or can I just note it's position and leave it in the ceiling?
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    Quote Originally Posted by rioguia View Post
    Yes
    No need for a j-box until you power up the wire.
    With reference to #2, which way will be easier to access the wire in the future? I would think an accessible box would be preferable
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    You do what you have planned, and leave the tails long at both ends so they will reach the first box on either end, OR, install a large emt or flex chase you can access later.
    Mar 2011
    Houston, TX
    I think that would be the best. Or very clearly mark it, at the least.
    If a inspector finds a piece of wire that is just laying, he will want to know where it terminates.
    "Just laying in the attic" is not the Ideal answer that the Inspector would like to hear.
    Feb 2009
    Colorado
    Like or not he has no code section to reject the installation.
    Mar 2011
    Houston, TX
    Quote Originally Posted by ActionDave View Post
    True that.
    It is amazing how a Insurance inspector will find a way to avoid payout.
    They sure don't have a problem taking your Insurance payments, no questions asked.
  1. Running a ground wire in conduit to plumbing
    By Juan for the road in forum Electrical Forum discussion & Blog
    Last Post: 08-16-2008, 03:06 AM
  2. Running wire between studs
    By hans_idle in forum Electrical Forum discussion & Blog
    Last Post: 01-04-2008, 03:54 PM
  3. Update on cutting a telephone wire.
    By got_nailed in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-22-2007, 07:52 PM
  4. Running wire through header
    By flyhop in forum Electrical Forum discussion & Blog
    Last Post: 11-29-2007, 07:17 PM
  5. Running a wire through a header
    By amartin725 in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2007, 04:06 PM
